Hi
I want to be able to display my catalogue online, the basic html export is rubbish but I really dont want to have to go nuts and start learning new stuff, I dont have the time.
Is there an easy and decent way to do this?
Nat.
Display my catalogue on the web
Traffik
J
Traffik
Traffik
When I go to export in the file menu I choose HMTL.
Then a window opens and at the top of this windows I click on the yellow folder icon called "open".
I then navigate to C:/ProgramData/AntMovieCatalog/Templates
Inside the templates folder are a number of htm and html template.
Some work perfectly, they export all the images and the html file
Some do not, they only export the html file, some create a pictures folder but its empty, other dont even create the pictures folder.
Some template actually use two files as template.
There are "Full" and "Individual" tabs.
The "full" tab is for one HTML page that has the whole list of movies, the "individual" tab is for making one HTML page per movie.
So some template are made for generating a list of the titles with links to the detail pages.
Traffik
