Dear Friends,
I need a way to change uppercase letters to lowcase letters when following HTML beginning tags
(i mean: <Table to <table or </Div to </div ecc.).
Do you think it could be possible?
Would you give me a statement example to insert in a script?
thanks in advance.
I doubt you can achieve that with regular expressions, but there is the LowerCase function that does that (it takes a string as input parameter and returns the lowercase function of it).
antp wrote:I doubt you can achieve that with regular expressions, but there is the LowerCase function that does that (it takes a string as input parameter and returns the lowercase function of it).
Thanks.
I know function Lowercase, but I need to change only words between < and >
or < and >
.... see this:
antp wrote:Isn't the case of the tags always the same between different movies, for a given site?
No, unfortunately sometime it happens, when changing pages lay-out of sites, that old pages have html tags with uppercase, new pages with lowercase (or vice-versa)....
It's not a great problem (if I see the changes or someone tells me about them), but, anyway, I was looking for a faster and more efficient way to solve problem, instead of running-after-it
uhm... maybe I could create a .pas file with my stringreplace statements.... what do you think?
bye
