Export to HTML Problems
AntsoftwareNewbie
Post by AntsoftwareNewbie »
HELP!
I'm trying to export my movie list to HTML so that I can print it properly since I can't get past the request for "A4" paper even if I set the properties on my printer to letter from the default of A4.
Problem with export to HTML is that it will only export the 1st 51 movies no matter what I try [resorting, selecting all movies in database].
Is there a way I can force it to export everything in the database? I think the 1st 51 movies that are exported are the first movies I entered into the database.
Please help as I'd like a printout for record keeping purposes.
Thanks!
That's strange that it cuts to 51st movie... Maybe a problem with this movie ?
But to change the paper size of Printing module it is easy : open the Report Designer and modify the template (File -> Page options, in the Report Designer). Then it should print on Letter paper next time you load the report in the Printing window.
