I'm trying to figure out how to get my version of amc reader to allow me to select the root folder other than my devices default storage. The version I have edited is 1.8.2 I think. The message below is a quote from the other thread is exactly what my problem is and elman seems to have it fixed in 1.9.1 version.
Quote
well, reason is quite simple - most people know nothing about /mnt/ or /. Therefore I'm pointing to default external storage directory, which might or might not be /mnt/sdcard/. In case of my phone it is /storage/sdcard0/.
Anyway, Rapidshare decided to delete my account, therefore download links don't work. Until I re-upload the app somewhere else, PM me with your e-mail and I will send you required pkg.
Or you could try to hard link your external drive to /mnt/sdcard/external/ and it should work.
Later I will add the option to change folders all the way to the root.
Elman"
End quote
Does anybody know what code elman changed to get this to allow me to pick location of XML file?
Any help would be great.
Thanks in advanced.
can any1 help please????
