[REL] Allmusic.com script
A new Release to extract information from Allmusic.com.
It can be used in 2 ways:
- Batch mode: in URL field you must supply album/CD page information link (i.e. http://www.allmusic.com/album/hanno-ucc ... 0002386981) (mode=1)
- Normal mode: supply only Album/CD title. (mode=0)
Authors=Fulvio53s03
Title=AllMusic
Description=import album
Site=http://www.allmusic.com
Language=IT, EN
Version=2.1
Requires=3.5.0
Comments=this script is based on the script AllGame from Scorpion7552.
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script
RequiresMovies=1
Mode=0|0|0=normal mode|1=batch mode (url)
[Parameters]
// TypeSearch=1|1|1=search for exact expression|2=search for any word
// TypeOrder=3|3|1=order by Artist|2=order by Album Title|3=order by relevance
// needs the following units
// StringUtils7552.pas
program AllMusic;
   StringUtils7552;
   AllMusicUrl = 'http://www.allmusic.com';                // base url
   AllAlbumUrl = 'http://www.allmusic.com';                // base url
   batchlogfic = 'c:\amc_Album_searchlog.txt';             // log for batch mode
   debug = false;                                          // debug mode on/off
   debugrep = 'c:\';                                       // directory where to save files
   CRLF3 = CRLF + ' ' + CRLF + ' ' + CRLF;
   CRLF2 = CRLF + ' ';
   CRLFCRLF = CRLF + CRLF;
//   CRLF_blank = CRLF + ' ';
   Credit_address, Readdress, Page: String;
   AlbumName, firstcall, abort, name, Dati_traccia, autori: String;
   Releases: String;
   Commento, save_value, indirizzo_pagina, ordine_lista, Salva_autore: String;
   value, sw_serie, StartDelimiter, endDelimiter : string;
   Album_ok: boolean;
   BatchMode, index: Integer;
   len_dopo, len_prima, num_char, num_linee, lungo, lgth_Pag_ricerca: Integer;
   CharCut, NumChar: integer;
   min_albName, min_alb, dopo, prima, brani, Track, newtrack, old_track, datitrack: String;
   titolo_e_autore, titolo, autore: String;
   batchlog, confbatch, memo: TstringList;
   pag_ricerca, save_pag, dati_album, artist, initchar, endchar: string;
   sw_giri, year: string;
   albumok: boolean;
   contatore: integer;
// list of albums
procedure GetList;
   Address, Line, urlmusic, album, albumtest, label, genre: String;
   Save_address, Title_album, indir_album: String;
   Editore: string;
   Relevance: String;
   ctr_loop, ValRelev: integer;
   found: boolean;
   i, lgth_dati_album: integer;
   PickTreeClear;                                                    // clear list
   indirizzo_pagina :=  AllMusicUrl+'/search/';
   Address :=  AllMusicUrl + '/search/album/' + UrlEncode(AlbumName) + ordine_lista;       //fs
   Page := GetPage(Address);
   Save_address := Address;
   found := False;
   PickTreeAdd('List of albums found for' + '"' + AlbumName + '"', '');
   if debug then
      DumpPage(debugrep+'AllMusicList.txt', Page);                // debug
   if Pos('album search results for', Page) = 0 then
      LogMessage('Error while reading selection page - no results found');
   initchar := '<ul class="search-results">';
   endchar  := '</ul>';
   pag_ricerca := initchar + TextBetween(Page, '<ul class="search-results">', '</ul>') + endchar;      //elenco titoli richiesti
   Normalizza_Page(pag_ricerca);
   save_pag := pag_ricerca;
   if debug then
      DumpPage(debugrep+'AllMusicSavePag.txt', save_pag);                // debug
   initchar := '<h4>Album</h4>';
   endchar  := '<h4>Album</h4>';
   dati_album := TextBetween (pag_ricerca, initchar, endchar) + endchar;     //dati_album contiene recursivamente i dati degli album
   if debug then
      DumpPage(debugrep+'AllMusicAlbum.txt', dati_album);                // debug
   delete(Pag_ricerca, 1, length(dati_album) - length(initchar));
   ctr_loop := 0;
   lungo := (Length(initchar) + length(endchar));
   lgth_dati_album := length(Dati_album);
   while (Length(Dati_Album) > Lungo) and (ctr_loop < 20) do                 //estraggo al massimo 20 titoli
      ctr_loop := ctr_loop + 1;
      initchar := '<div class="title">';
      endchar  := '</div>';
      indir_album := textBetween(dati_album, initchar, endchar);
      initchar := '<a href="http://';
      endchar  := '"';
      Address  := textBetween(indir_album,initchar, endchar);                //indirizzo album
      initchar := '>';
      endchar  := '</a>';
      Title_album  := textBetween(indir_album,initchar, endchar);            //titolo dell'album   //Fs fino qui $$$$$$$$$$$$$$$$$$$$
      initchar := '<div class="artist">';
      artist := textbetween(dati_album, initchar, endchar);
      artist := textbetween(artist, '>', '<');
      initchar := '<div class="year">';
      year := textbetween(Dati_album, initchar, endchar);
      year := fulltrim(year);
      Title_Album := Title_Album + ' (' + artist + ', ' + year + ')';
      Address := 'http://' + Address;
      PickTreeAdd(Title_Album, Address);
      found := True;
      delete(Pag_ricerca, 1, lgth_dati_album);
   if not found then
      LogMessage('No album found for '+AlbumName);
      AnalyzeMusicPage(Address);                                    // Album page
      LogMessage('No album selected');
// ANALYZE MUSIC PAGE
procedure AnalyzeMusicPage(Address: string);
   Line, urlmusic, cover, Lenght, Pays: String;
   Autore, Commenti, str_min: String;
   minu, minuti, ore, lgth_comm, save_lgth_comm: integer;
   j: Real;
   Page := UTF8decode(Page);
//   if debug then
//      DumpPage(debugrep+'AllMusicPageDetail.txt', Page);             // debug
   Readdress := '';
   Readdress := textbetween(Page, '<meta property="og:url" content="', '">');
   if length(Readdress) > 0 then
      Address := Readdress;
   if Pos('class="album-artist"', Page) = 0 then
   Begin
      LogMessage('Error while reading album page');
   Normalizza_Page(Page);
   albumok := True;
   if debug then
//titolo tradotto
   Value := TextBetween(Page, '<h2 class="album-title" itemprop="name">', '</h2>');
   SetField(fieldTranslatedTitle, FormatText(Value));
//Allmusic Rating
   Value := TextBetween(Page, 'itemprop="ratingValue">', '<');
   SetField(fieldRating, FormatText(Value));
//*** artist url
   urlmusic := 'href="/cg/amg.dll';                               // url to search (first occurence)
   Value := TextBetween(Page, '<span class="title">', 'class="subtitle');
//*** artist name (=OriginalTitle)
   Value := TextBetween(Page, '<h4>', '</h4>');
   Value := TextBetween(Value, 'title="', ' Discography');
   SetField(fieldDirector, FormatText(Value));
   SetField(fieldOriginalTitle, FormatText(Value));
   Salva_autore :=FormatText(Value);
//*** release date (year only)  ('month year' 'month day, year' or 'year')
   Value := TextBetween(Page, '<div class="release-date">', '</div>');
   value := textbetween(Value, '<span>', '</span>');
   Value := FormatText(Value);
   i := LastPos(' ', Value);                                          // extract year only
   if i > 0 then Value := Copy(Value, i+1, length(Value));
   SetField(fieldYear, Value);
//*** duration
   Value := TextBetween(Page, ' <div class="duration">', '</div>');
   value := textbetween (Value, '<span>', '</span>');
//   setfield(fieldlength, value);
   ore    := strtoint(TextBefore (Value, ':', ''), 0);
   str_min := TextBetween (Value, ':', ':');
   minuti := strtoint(str_min, 0);
   if minuti > 0 then
      Minu := ore*60 + Minuti;
   if minuti = 0 then
      Minu := ore;
   str_min := inttostr(Minu);
   SetField(fieldLength, str_Min);
//*** genre (= category)
   if debug then
      DumpPage(debugrep+'AllMusicPage.txt', Page);             // debug
   Value := TextBetween(Page, '<div class="genre">', '<div class="styles">');
   Value := TextBetween(Value, '<div>', '</div>');
   SetField(fieldCategory, FormatText(Value));
//*** cover
   cover := TextBetween(Page, '<div class="album-cover">', '</div>');
   cover := TextBetween(cover, '<img src="', '"');
   if CanSetPicture then
      GetPicture(cover);
//*** label
   Value := FormatText(TextBetween(Page, '<h3>Label</h3>', '</p>'));
   if Value = '' then
      SetField(fieldProducer, 'No label');
   if Value <> '' then
//*** album review (= comments)
   initchar := '<section class="review read-more"';
   endchar  := '</section>';
   Value := TextBetween(Page, initchar, endchar);
   Value := initchar + Value + endchar;
   HTMLRemovetags(Value);
   Value := stringreplace (Value, ('Review' + CRLF), 'Review ');
   if Value = '' then
      Commenti := '--- No Review Available ---'
      Commenti := Value;
//   GetReleases;
   Value := TextBetween(Page, '<div id="releases">', '</div>');
//   GetReleases;									//fs2015.01.03
   Commenti := UTF8decode(Commenti) + CRLF + UTF8decode(Releases);
   lgth_comm := length(commenti);
   save_lgth_comm := length(commenti);
          save_lgth_comm := lgth_comm;
          commenti := StringReplace(commenti, CRLF2, CRLF);
          commenti := StringReplace(commenti, CRLFCRLF, CRLF);
   until save_lgth_comm = lgth_comm;
   Commenti := stringreplace(Commenti, '.', '.   ');
   Setfield(FieldComments, commenti);
   Value := Page;
   pag_ricerca := TextBetween(Value, ' <section class="track-listing">', '</section');       //fs 2015.01.02
   Value := TextBetween(Value, '<tbody>', '</tbody>');
   delete(Page, 1, length(Value));
   brani := '';
   estrazione_tracce;
   HTMLRemoveTags(brani);
   SetField(fieldDescription, brani);
   Credit_address := Address + '/credits';
   AnalyzeCreditsPage;
procedure GetReleases;
   Dato_Release: String;
   CharAbNormal := '<td class="cell">';                       //elimino i dati inutili
   CharNormal := '';
   Value := StringReplace(Value, CharAbNormal, CharNormal);
   CharAbNormal := '</td>';
   CharNormal := ' ';
   CharAbNormal := CRLF;
   CharNormal := '';
   StartDelimiter := '<tr class="visible">';                  //mi posiziono su inizio dati significativi
   EndDelimiter   := '</tr>';
   lungo := length(textbefore(Value, StartDelimiter, ''));
   delete(Value, 1, lungo);
   Lungo := (Length(StartDelimiter) + length(EndDelimiter));
   Dato_release := StartDelimiter + TextBetween(Value, StartDelimiter, EndDelimiter) + EndDelimiter;
   delete(Value, 1, length(Dato_release));
   Dato_release := Trim(TextBetween(Value, StartDelimiter, EndDelimiter));
   Releases := '--- Releases ---' + CRLF + Dato_release;
   while Length(Dato_Release) > Lungo do
//      Dato_release := FormatText(Dato_release);
      Releases := Releases + CRLF + Dato_release;
Procedure estrazione_tracce;
Begin
//fs 2015.01.02    pag_ricerca := value;
    if debug then
       DumpPage(debugrep+'AllMusicList_pag_ricerca.txt', pag_ricerca);                // debug
    initchar := '<tr class="track';
    endchar :=  '<tr class="track';
    Dati_traccia  := initchar + TextBetween(Pag_ricerca, initchar, endchar) + endchar;
    delete(Pag_ricerca, 1, length(Dati_traccia));
    while Length(Dati_traccia) > Lungo do    //esegui se trovato qualcosa
       datitrack := '';
       track := '';
       initchar := '<td class="tracknum">';
       endchar  := '</td>';
       track := textbetween(dati_traccia, initchar, endchar);           //n.d'ordine
       track := StringReplace(track, CRLF, '');
       track := Fulltrim(track);
//       datitrack := datitrack + track;
       if length(track) > 0 then
          brani := brani + track + '  ';
       delete(Dati_traccia, 1, (pos(Initchar, dati_traccia) + length(track) + length(initchar) + length(endchar)));
       initchar := '<td class="title-composer">';
       endchar  := '</td>';
       track := textbetween(dati_traccia, initchar, endchar);            //titolo brano e compositore
       titolo := Textbetween(track, 'itemprop="url">', '</a>');             //fs20141115  titolo
       autore := Textbetween(track, '<div class="composer">', '</a>');      //fs20141115
       autore := FormatText(autore);                                         //fs20141115
       if length(autore) = 0 then
           initchar := '<span itemprop="name">';
           endchar  := '</a>';
           track := Textbetween(dati_traccia, '<span itemprop="name">', '</a>');      //fs20141115
           autore := FormatText(track);                                         //fs20141115
       titolo_e_autore := titolo + '     (' + autore + ')';                 //fs20141115  titolo + autore
       datitrack := datitrack + ' ' + titolo_e_autore;                      //fs20141115
       if datitrack = old_track then
          datitrack := ''
          datitrack := datitrack + CRLF;
       old_track := datitrack;
       datitrack := StringReplace(datitrack, CRLF2, ' ');   //fs 2012.10.28
//fs2015-01-03
       index := length(datitrack);
//fs2015-01-03       while index < 42 do
       while index < 0 do                     //fs2015-01-03
             datitrack := datitrack + ' ';
             index := index +1;
       datitrack := fulltrim(datitrack);
       if length(datitrack) > 3 then
          brani := brani + datitrack + CRLF;                  //fs 2014.11.15
// reimposto l'area su cui loopare
       initchar := '<tr';
       endchar  := '</tr>';
       dati_traccia := initchar + TextBetween (pag_ricerca, initchar, endchar) + endchar;     //dati_album contiene i dati dell'album
       lgth_Pag_ricerca := length(Pag_ricerca);             //fs 2012.03.25 debug
//fs ********************* fine nuova estrazione tracce *****************************************
// ANALYZE Credits PAGE
procedure AnalyzeCreditsPage;
   Line, urlmusic, cover, Lenght: String;
   j: Real;
   Page := GetPage(Credit_address);
   NumChar := length(Page);
   if debug then
      DumpPage(debugrep+'AllMusicCreditDetail.txt', Page);             // debug
   if Pos('Credits', Page) = 0 then                              // may be this test is OK?
   Begin
      LogMessage('Error while reading credits page');
   albumok := True;
// ***************************** estrae i credits ***********************************************
   Value := TextBetween(Page, '<section class="credits">', '</section>');
   NumChar := length(Value);
   Getcredits;
// ************************ fine estrae i credits (copiato dalle tracce) ************************
   Save_value := '"' + Salva_autore + '":' + CRLF + Save_Value;
//   Save_value :=  UTF8Decode(Save_value);            //fs 2012.03.24
   Save_value := RemoveHTML(Save_value);
   SetField(fieldActors, Save_value);
procedure GetCredits;
Begin
   Save_Value := '';
   Commento := '* ';
   if debug then
      DumpPage(debugrep+'AllMusicCreditDetailExtract.txt', Value);             // debug
   While Commento <> '' do
      StartDelimiter := '<a href="http://www.allmusic.com/';
      CharCut := Pos(StartDelimiter, Value);
      EndDelimiter   := '</a>';
      Commento := TextBetween(Value, StartDelimiter, EndDelimiter); // estrae nome
      Commento := TextAfter(Commento, '>');
      CharCut := CharCut + length(StartDelimiter) + length(Commento) + length(EndDelimiter);
      delete(Value, 1, CharCut);
      Save_Value := Save_value + commento;
      if commento <> '' then
      Save_Value := Save_value + ': ';
      StartDelimiter := '<td class="credit"';
      EndDelimiter   := '</td>';
      Commento := StartDelimiter + TextBetween(Value, StartDelimiter, EndDelimiter); // estrae strumento
      CharCut := CharCut + length(Commento) + length(EndDelimiter);
      Commento := stringreplace(Commento, CRLF, '');
      HTMLRemoveTags(Commento);
      HTMLDecode(Commento);
      Commento := trim(Commento);
//fs 2012.03.23         Save_Value := Save_value + commento + ';' + crlf;
      Save_Value := Save_value + commento + ';' + '         - ';     //fs 2012.03.23
    Save_value := copy(Save_value, 1, length(Save_value) - 6);      // tolgo ultimo separatore
Procedure Normalizza_page(Pagina: string);    // elimina i crlf, trasforma delimiters maiuscoli in minuscoli
  CharAbNormal := crlf;
  CharNormal := ' ';
  pagina := StringReplace(pagina, CharAbNormal, CharNormal);
  CharAbNormal := '<B';
  CharNormal := '<b';
  CharAbNormal := '</B';
  CharNormal := '</b';
  pagina := StringReplace(Value, CharAbNormal, CharNormal);
  CharAbNormal := '<FONT';
  CharNormal := '<font';
  CharAbNormal := '</FONT';
  CharNormal := '</font';
  CharAbNormal := '<TR';
  CharNormal := '<tr';
  CharAbNormal := '</TR';
  CharNormal := '</tr';
  CharAbNormal := '<TD';
  CharNormal := '<td';
  CharAbNormal := '</TD';
  CharNormal := '</td';
  CharAbNormal := '<DIV';
  CharNormal := '<div';
  CharAbNormal := '</DIV';
  CharNormal := '</div';
   if BatchMode > 0 then
      ShowWarning(m);
   batchlog.Add(m);
   batchlog.SaveToFile(batchlogfic);
// process batch mode
procedure AllMusicBatch;
   AlbumName := GetField(fieldUrl);                      // if no url or another site then ignore
   if (AlbumName <> '') and (Pos(AllAlbumUrl, AlbumName) > 0) then
      AnalyzeMusicPage(AlbumName)
      LogMessage('ignored url="'+AlbumName+'"');
// process normal mode
procedure AllMusicNorm;
   albumok := False;
   AlbumName := GetField(fieldTranslatedTitle);           // get album name
   value := getField(fieldTranslatedTitle);
   if not Input('AllMusic - ' + Value, 'Enter the name of the album :' + crlf, AlbumName) or (AlbumName = '') then exit;
   GetList;
      until albumok;
//  start here
   if abort = 'o' then exit;                                   // batch mode aborted
   if firstcall <> 'done' then
   begin                                                      // 1st call: init parameters
      firstcall := 'done';
      if not CheckVersion(3,5,0) then
         abort := 'o';
      if BatchMode > 0 then                                  // batch mode: confirm the choice
         batchlog := TStringList.Create;                     // init batch log
         batchlog.Add('starting batch mode');
         batchlog.Add(StringOfChar('*',80));
// confirmation message
         confbatch := TStringList.Create;
         confbatch.Add('You have selected the batch mode:');
         confbatch.Add('Did you save your database?');
         confbatch.Add('*** Address to extract must be supplied in Field Url ***');
         confbatch.Add('');
         confbatch.Add('At the end of treatement:');
         confbatch.Add('- look at the file ' + batchlogfic + ' for errors/infos');
         confbatch.Add('- the albums found will be checked, the others not (for the selection)');
         confbatch.Add(' (see: Tools/Preferences/Movie list/checkboxes)');
         confbatch.Add('');
         confbatch.Add('confirm your choice');
         if not ShowWarning(confbatch.Text) then
           AddToLog('batch mode aborted');                   // batch mode not confirmed = abort
            abort := 'o';
// let's go
   if BatchMode = 0 then
      AllMusicNorm
      AllMusicBatch;
Enjoy it.
PinkFloyd
Post by PinkFloyd »
Thank you very much fulvio53s03.
xenesys
Post by xenesys »
Works great (again ^^) :)
but informations in the "actors" field are like this :
"King Diamond":
- Jorgen Bak: Photography; - Mikkey Dee: Assistant Producer, Drums; - Michael Denner: Assistant Producer, Composer, Guitar; - George Duning: Composer; - Roberto Falcao: Engineer; - Timi Hansen: Guitar (Bass); - Thomas Holm: Artwork; - Torbjorn Jorgensen: Artwork; - King Diamond: Composer, Primary Artist, Producer, Vocals; - Andy LaRocque: Composer, Guitar;
Can it be possible to organise it and copy it in the "comments" field (bigger than "actors" field - easier to read) ?
"King Diamond":
thanks again for all scripts !!
xenesys wrote: Can it be possible to organise it and copy it in the "comments" field (bigger than "actors" field - easier to read) ?
Obviously it can be possible but, after that, all people who used the script till today would have their informations swapped from a field to another....
I think best thing you could do is manipulating a language file (expanding a field and collapsing another) for your personal use and afterward sharing that file to other people interested.
More simply, after extracting, you can use "Swap fields" script.
(another reason I don't want to change scripts is that I have some personal print template and I don't want to change them :hihi:)
bye,
xenesys
Post by xenesys »
OK I understand.
I will see with the "Swap fields" script.
thanks for the help.
xenesys wrote:OK I understand.
Maybe another solution could be a new template to display information using menu option:
'DISPLAY' ----> 'Display HTML'
and selecting tha new template (or another, if one adequate already exists).
I'll work on it.
