Startrek script problem
RIP
Post by RIP »
When I try to run the statrek script the following error apears: Cannot open file StarTrekScript_cache.txt
Why apperantly, this script has an "add-on" file which I don't have???! :/
RIP
Update
Post by RIP »
I created an empty file whith the name of the one missing and it seems to work! You should have provided it with the scripts pack!! :/
Yet! that's not all! the script asks me for a site when I write www.startrek.com (guessed) it gives another error! :( this time is: error in page
The address you have to enter is one of the following :
http://www.startrek.com/library/episodes_TOS.asp
http://www.startrek.com/library/episodes_DS9.asp
http://www.startrek.com/library/episodes_TNG.asp
http://www.startrek.com/library/episodes_voy.asp
You can also have a "code" already in the Original Title field so select which address to use so you do not have to enter them:
TOS
DS9
TNG
VOY
or:
Original Series
Deep Space
Next Generation
Voyager
It's not me that made the script, but I'll maybe correct it so it asks to select from a list instead of entering the address...
trekkie
Post by trekkie »
I've improved the original script so you don't have to type
a URL .
Just select a series in case your episode title does NOT contain the series name or the script can't figure out the series.
// GETINFO SCRIPTING
// Paramount StarTrek.Com import Episode Info With picture
*  Episode Information importation script for:     *
*      StarTrek(US), http://www.startrek.Com       *
*  (c) 2003 Trekkie     asimov@hotmail.com         *
*  For use with Ant Movie Catalog 3.4.0            *
*  www.ant.be.tf/moviecatalog ··· www.buypin.com   *
*  The source code of the script can be used in    *
*  another program only if full credits to         *
*  script author and a link to Ant Movie Catalog   *
*  website are given in the About box or in        *
*  the documentation of the program                *
program StarTrek;
   ImportLongDescription = True;   // True - All Episode Description.
                                   // False - Only Short Synopsis
   ImportLargePicture  =   True;   // True - A Larger Pictures of the Episodes Will Be Imported
                                   // False - A Small Thumbnail Picture Will be Imported
   StorePictureInDatabase = True;  // False - Will Store the Picture Externally
   ImportComments = True;          // Comment Will Contain : Writers & Teleplay Info,Production
                                   // Number & Stardate
   ImportGuestCast = True;         // Add Info on Guest Cast to Actors field
   OnErrorWholeList = True;       // If Episode Title not found
                                  // display a list of ALL episodes to choose from
   VerboseMode = True;            // True - Will Display Error messages
  // Use Only ONE of the following Episode Titles Templetes:
  // Uncomment only ONE template
   TitleTemplate = 'Series - Episode Nr -  Title';   // Example: Star Trek TOS - 1x01 - The Cage
// TitleTemplate = 'Title -  Episode Nr -  Series';  // Example: The Cage - 1x01 - Original Series
// TitleTemplate = 'Title -  Series';                // Example: The Cage - TOS
// TitleTemplate = 'Series - Title';                 // Example: DS9 - Dax
// TitleTemplate = 'Title';                          // Example: The Cage
  // If CacheMode is TRUE you should verify a file 'StarTrekScript_Cache.txt'
  // Exists in the Scripts Directory Under Ant Movie Catalog Install Directory
  // If not you MUST (at First Run ) create an EMPTY File and put it in that directory.
   CacheMode   = True;            // True - Will Store A Series Listing in File and
                                  // Use it to offload server queries
                                  // False - Will Query Series Episode listing for every entry
  EpisodeTitle,OriginalTitle: string;
  TheEpisodesListing: string;
  PickTreeSelected,TitleCorrected,CacheExists:Boolean;
  CacheFile:TStringList;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
Function GetEpisodeAddress(Line:String):String;
  BeginPos,EndPos:Integer;
Begin
   Result:='';
   BeginPos:= Pos('a href=',Line);
   BeginPos:= BeginPos +8;
   EndPos:= Pos('">',Line);
   Result:=Copy(Line,BeginPos, EndPos-BeginPos);
End;
  LineNr,TitleLineNr: Integer;
  Line:String;
  Title,EpisodeAddress:String;
  if CacheMode Then
    if not CacheExists then
       CacheFile.Free;
       CacheFile:=TStringList.Create;
       CacheFile.Add(Address);
       For LineNr:=0 to Page.Count -1 do
       Begin
          CacheFile.Add(Page.GetString(LineNr));
       End;
       For LineNr:=0 to CacheFile.Count -1 do
       Begin
          Page.Add(CacheFile.GetString(LineNr));
       End;
  // Find The Selected Episode in The Whole Episode Listings
  LineNr := FindLine('<TABLE STYLE=',Page,0);
  if LineNr > 0 Then
    Line :=Page.GetString(LineNr);
    TitleLineNr := FindLine(EpisodeTitle, Page, LineNr);
    if TitlelineNr > -1 then
       // Title
       Line :=Page.GetString(TitleLineNr);
       EndPos:=Pos('</A>',Line);
       Title:=Copy(Line,1,EndPos-1);
       // Address
       Line :=Page.GetString(TitleLineNr-1);
       EpisodeAddress:=GetEpisodeAddress(Line);
       Address:='http://www.startrek.com' + EpisodeAddress;
       EndPos:=Pos('Part I',EpisodeTitle);
       if (EndPos <> 0) and (Length(EpisodeTitle) > 7) then
          Title:=Title + ' ';
       // Find Next Matching Titles
       LineNr:= FindLine(Title,Page,TitleLineNr+1);
       if LineNr > -1 then
          PickTreeAdd('Matching Episode Titles for: ' + EpisodeTitle, '');
          PickTreeAdd( Title, 'http://www.startrek.com' + EpisodeAddress);
          AddEpisodesTitles(Page,LineNr);
          PickTreeSelected:=PickTreeExec(Address);
          if Not PickTreeSelected Then
              Exit;
       End;
    End
    Else
    Begin
          if OnErrorWholeList  then
          Begin
            PickTreeAdd('Select A Title Closest to: '+ EpisodeTitle, '');
            DisplayAllTitles(Page,LineNr);
              Exit;
          End
              if VerboseMode then
                 Showmessage(' Episode ' + EpisodeTitle + ' Not Found');
              Exit;
          End;
    End;
    HTMLDecode(Address);
    Page:=TStringList.Create();
    // Handle Page redirection
    LineNr:= FindLine('window.location.replace',Page,0);
    if LineNr > -1 then
      Line:=Page.GetString(LineNr);
      BeginPos:= Pos('replace',Line) + 9;
      EndPos := Pos(')',Line) -1;
      Address:=Copy(Line,BeginPos, EndPos-BeginPos);
      Address:='http://www.startrek.com' + Address;
    End;
    AnalyzeEpisodePage(Page);
     if VerboseMode then
       ShowMessage('Error In Page for ' + EpisodeTitle);
procedure DisplayAllTitles(Page: TStringList; var LineNr: Integer);
  Line,Title,Address,Season: string;
  BeginPos,EndPos,EndLine: Integer;
  LineNr:=LineNr +1;
  EndLine :=  FindLine('</HTML>',Page,LineNr);
  While (LineNr < EndLine) do
         BeginPos:=Pos('SEASON',Line);
         if BeginPos <> 0 Then
         Begin
               EndPos:=Pos('</b>',Line);
               Season:=Copy(Line,BeginPos,EndPos-BeginPos);
               PickTreeAdd(Season,'');
         End;
         EndPos:= Pos('</A></TD>',Line);
         if EndPos <> 0 then
         Begin
              	 // Title
          	 // Address
        	 Line :=Page.GetString(LineNr-1);
         	 PickTreeAdd(Title, 'http://www.startrek.com' + Address);
         End;
         LineNr:=LineNr+1;
  End; //while
procedure AddEpisodesTitles(Page: TStringList; var LineNr: Integer);
  Line,Title,Address: string;
  EndPos: Integer;
  While (LineNr > -1) do
   // Title
    // Address
    LineNr:= FindLine(EpisodeTitle,Page,LineNr+1);
  End;
function FindValue(BeginTag,EndTag:String;                                       Page:TStringList; var LineNr:Integer):String;
 Line,Value:String;
 A:Char;
  Value:='';
  BeginPos:=0;
  Repeat
     BeginPos := pos(BeginTag, Line);
     LineNr:=LineNr+1;
  Until ((BeginPos <> 0) or (LineNr > Page.Count-1 ));
  if BeginPos > 0 then
       BeginPos := BeginPos + Length(BeginTag);
       LineNr:=LineNr - 1;
  if BeginTag = EndTag then
     Delete(Line,1,BeginPos);
     BeginPos:=1;
  End;
  EndPos := pos(EndTag, Line);
  While ((EndPos = 0) and (LineNr < Page.Count-1 ) ) do
       Value := Value + copy(Line, BeginPos, Length(Line) - BeginPos);
       // Next Lines
       BeginPos:= 0;
       LineNr:= LineNr+1;
       Line:= Page.GetString(LineNr);
       EndPos := Pos(EndTag,Line);
  End;
  Value:= Value + copy(Line, BeginPos, EndPos - BeginPos);
  Result:=Value;
End;
procedure AnalyzeEpisodePage(Page: TStringList);
  Production,StarDate,Year,PictureAddress:String;
  LineNr,DirectorLine,StartLine: Integer;
  BeginPos, EndPos: Integer;
  PicturePage:TStringList;
// Original Title & Year , Production Nr & Star Date
  StartLine := FindLine('Begin Episodes List', Page, 0);
  LineNr:=StartLine+1;
  Value:=FindValue('<B>','</B>',Page,LineNr);
  if Value <> '' Then
    HTMLDecode(Value);
    if PickTreeSelected or TitleCorrected Then
    Begin
      Value2:=Getfield(fieldOriginalTitle);
      FullValue:= StringReplace(Value2,OriginalTitle,Value);
      SetField(fieldOriginalTitle,FullValue);
    End;
    Year:='';
    // Concatenate Next 2 Lines
    BeginPos := Pos(EpisodeTitle,Line);
    Value:=Line;
    Line:=Page.GetString(LineNr+1);
    Value:=Value + Line;
    HTMLRemoveTags(Value);
    BeginPos:= Pos('Production',Value);
    Begin
       Production:= Copy(Value,BeginPos,14);
       EndPos :=  Pos('Stardate',Value);
       StarDate := copy(Value,EndPos,Length(Value) - EndPos);
       Year:=Copy(Value,BeginPos + 14,EndPos -BeginPos -14);
       EndPos:=Length(Year);
       Year:=Copy(Year,EndPos-3,4);
    End;
    SetField(fieldYear, Year);
      if VerboseMode then
         ShowMessage('Could Not Find Episode Title')
  // Picture
  if not ImportLargePicture then
       LineNr := FindLine('<IMG SRC=/content/Photo/', Page, StartLine);
       if LineNr > -1 then
         BeginPos := pos('Photo', Line) + 5;
         Delete(Line, 1, BeginPos);
         EndPos := pos('ALIGN', Line) -1;
         Value := copy(Line, 1, EndPos);
         PictureAddress:='http://www.startrek.com/content/Photo/'+ Value;
         GetPicture(PictureAddress, not StorePictureInDatabase); // False = do not store picture          // externally ; store it in the catalog file
   Begin
        LineNr := FindLine('/art/tinyicons/PHOTO.gif', Page, StartLine);
        if LineNr > -1 then
          Line:=Page.GetString(LineNr-2);
          BeginPos:=Pos('href="',Line) + 6;
          EndPos:=Pos('">',Line);
          Value:= Copy(Line,BeginPos,EndPos-BeginPos);
          PictureAddress:='http://www.startrek.com'+ Value;
          PicturePage:=TStringList.Create();
          PicturePage.Text := GetPage(PictureAddress);
          LineNr:=FindLine('/content/PHOTO/',PicturePage,0);
          if LineNr > -1 then
          Begin
             Line:=PicturePage.GetString(LineNr);
             BeginPos:=Pos('PHOTO',Line) + 5;
             PictureAddress:='http://www.startrek.com/content/PHOTO'+ Value;
          End
          PicturePage.Free;
        End;
  End;
  // Director
  DirectorLine:=0;
  LineNr := FindLine('Director:', Page, StartLine);
  if LineNr > -1 then
    DirectorLine:=LineNr;
    HTMLDecode(Value);
    if VerboseMode then
       ShowMessage('Could Not Find Director Paragraph');
  // Actors
  LineNr := FindLine('Cast:', Page, StartLine);
  if LineNr > -1 then
    FullValue := '';
    LineNr:=LineNr+1;
    Value2:='Guest Cast';
    if ImportGuestCast then
       Value2:='Creative staff';
    While (Pos(Value2,Line) = 0) do
      HTMLRemoveTags(Line);
      if (FullValue <> '') and (Length(Line) > 1 ) then
      FullValue := FullValue + Line;
      LineNr:=LineNr+1;
    HTMLDecode(FullValue);
    if VerboseMode then
        ShowMessage('Could Not Find Cast Paragraph');
  //Country
  Value := 'United States';
  //Category
  Value := 'Science Fiction';
  // Language
  Value := 'English';
  // Producer
  Value := 'Paramount Pictures';
  //Description
  LineNr := FindLine('Synopsis:', Page, StartLine);
  if LineNr > -1 then
    LineNr:=LineNr +1;
    if ImportLongDescription Then
       FullValue := '';
       While ( Pos('Related Links',Line) = 0 ) do
          Line:=StringReplace(Line,#11,' ');
          Line:=StringReplace(Line,'&#151',' ');
          LineNr:=LineNr +1;
       End;
       FullValue:=FindValue('<B>','</B>',Page,LineNr);
    HTMLRemoveTags(FullValue);
    SetField(fieldDescription, FullValue);
  // Comments
  if ImportComments then
        FullValue := '';
        LineNr :=DirectorLine +1;
        While(Pos('p class',Line) = 0 ) do
            if FullValue <> '' then
            LineNr := LineNr + 1;
         End;
         FullValue:=FullValue + #13#10 + Production + ' ' + Stardate;
         SetField(fieldComments, FullValue);
   End;
   DisplayResults;
function CorrectEpisodeTitle (Title:string):string;
var Words:Array of string;
    Replace,Original:String;
    Index:Integer;
   Title := AnsiMixedCase(Title,' ');
   TitleCorrected:=False;
   Setarraylength(Words,10);
   Words[0]:=' In ';
   Words[1]:=' On ';
   Words[2]:=' Of ';
   Words[3]:=' As ';
   Words[4]:=' The ';
   Words[5]:=' At ';
   Words[6]:=' And ';
   Words[7]:=' A ';
   Words[8]:=' An ';
   Words[9]:=' To ';
   for Index:=0 to 9 do
     if Pos(Words[Index],Title) <> 0 then
       Original:=Words[Index];
       Replace:=AnsiLowerCase(Original);
       Title:=StringReplace(Title,Original,Replace);
       TitleCorrected:=True;
     End;
   End;
   Result:=Title;
End;
  BeginPos,EndPos,Len:Integer;
  Template,BaseAddress:String;
  if CheckVersion(3,4,0) then
    TheEpisodesListing:='';
    if CacheMode Then
       CacheFile.LoadFromFile('StarTrekScript_Cache.txt')
    End;
    EpisodeTitle := GetField(fieldOriginalTitle);
    if EpisodeTitle = '' then
       EpisodeTitle := GetField(fieldTranslatedTitle);
    PickTreeAdd('Select A Star Trek Series','');
    BaseAddress:='http://www.startrek.com/library/';
    if (Pos('TOS',EpisodeTitle) > 0) or (Pos('Original Series',EpisodeTitle) > 0 ) Then
    Begin
      TheEpisodesListing:= BaseAddress+'episodes_TOS.asp';
    End;
    PickTreeAdd('The Original Series',BaseAddress +'episodes_TOS.asp');
    if (Pos('DS9',EpisodeTitle) > 0) or (Pos('Deep Space',EpisodeTitle) > 0 ) then
    Begin
      TheEpisodesListing:= BaseAddress + 'episodes_DS9.asp';
    End;
    PickTreeAdd('Deep Space Nine',BaseAddress+'episodes_DS9.asp');
    if (Pos('TNG',EpisodeTitle) > 0) or ( Pos('Next Generation',EpisodeTitle) > 0 ) then
    Begin
      TheEpisodesListing:= BaseAddress+'episodes_TNG.asp';
    End;
    PickTreeAdd('The Next Generation',BaseAddress+'episodes_TNG.asp');
    if ( Pos('VOY',EpisodeTitle) > 0) or (Pos('Voyager',EpisodeTitle) > 0 ) then
    Begin
      TheEpisodesListing:= BaseAddress+ 'episodes_voy.asp';
    End;
    PickTreeAdd('Voyager',BaseAddress+'episodes_voy.asp');
    if TheEpisodesListing = '' then
    Begin
         if not PickTreeExec(TheEpisodesListing) Then
         Begin
            ShowMessage('You Must Select A Series');
            Exit;
         End;
    End;
    CacheExists:=False;
    if CacheMode Then
    Begin
      if CacheFile.Count > 0 Then
      Begin
        // verify the Cache is for the same star trek series
        CacheExists:= (FindLine(TheEpisodesListing,CacheFile,0) > -1 );
      End;
    End;
 // Extract Episode Title from template
    Template:= TitleTemplate;
    BeginPos:=Pos('-',EpisodeTitle);
    Len:= Length(EpisodeTitle);
    case Template of
    'Series - Episode Nr -  Title':
       Begin
          Delete(EpisodeTitle, 1, BeginPos);
       End
    'Title -  Series':
       Begin
          Delete(EpisodeTitle, BeginPos, Len);
       End
    'Title -  Episode Nr -  Series':
       Begin
       End
    'Series - Title':
       Begin
       End
    'Title':
    Else
       Begin
          if VerboseMode then
             ShowMessage('Episode Title does not match the template: ' + Template);
          Input('Star Trek Episode Guide Import', 'Enter Episode Title', EpisodeTitle);
       End;
    End; // Case
    EpisodeTitle := Trim(EpisodeTitle);
    OriginalTitle:= EpisodeTitle;
    EpisodeTitle:=CorrectEpisodeTitle(EpisodeTitle);
    AnalyzePage(TheEpisodesListing);
     ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the                 version 3.4.0)');
  if CacheMode Then
       CacheFile.SaveToFile('StarTrekScript_Cache.Txt');
       CacheFile.Free;
Have fun with it ;)
