Suggestion: Advanced export option
lukecs
Post by lukecs »
On your web page it shows that you are considering adding a ftp feature on a future release. When I saw this I said great, updating my movie list is a pain in the butt... I have a few hundred movies and updating all of them or finding out which ones have been changed is a big pain. But making an ftp add on would be hard, so in the mean time how about this.
An option to export only files changed since last export
Sure, that was planned, but you can do that with any FTP program : you usually have a "Compare directories" function allowing you to see files that differ (e.g. in LeechFTP it sees a file as "new" if the size is different, but not the date, which is nice if you use the "individual" html export since the html files of each movie is recreated at each export).
lukecs
Post by lukecs »
Thanks. I couldn't find that feature in the programs I use ws_ftp or cute ftp.
