Automatic script importing
Álvaro
Post by Álvaro »
How can I do that without pressing 'Save' for each entry every time? I remember I did that once: just two or three clicks and the program imported all the data without my assistance.
Raoul_Volfoni
Post by Raoul_Volfoni »
In the scripting window (F6), at the top right position uncheck "Show results window" or in spanish "Mostrar ventana de resultados"
Álvaro
Post by Álvaro »
Thank you. (Also, I see now, the script i'm using (Filmaffinity ES) has some special options, and it's required to check "DontAsk)".
