Script for covers Allcdcovers movies
cluis_henrique
__________
cluis_henrique
correction
___________
cluis_henrique
correction
program allcdcoversLHC;
var MovieName:string;
uses StringUtils1;
procedure AnalyzeFilmPage(Address:string);
var Page:TStringList;
PRE, INI,FIM,valor, Pag, Pag2, Text, valor2, w:String;
j, i, min, Code, min2:integer;
wl:boolean;
PRE:='http://www.allcdcovers.com' ;
INI:='/download/';
FIM:='">';
Pag := GetPage(Address);
valor:=TextBetween(pag,INI,FIM);
valor2:=PRE+INI+valor;
If length(valor) > 0 then begin
i := AddExtra;
GetExtraPicture(i,valor2);
End;
Page.free;
i,nLine,LineNr,EndPos: Integer;
Pag,Line,Search,Endsearch,INI,FIM: string;
url, nome_filme: string;
Search:='search/movies/all/';
Page.Text := GetPage(Address+Search+MovieName);
if (pos('Did you mean', Page.Text) = 0) then
LineNr := 0;
nLine:=0;
pag := page.text;
INI := 'toggleVersionListCovers';
FIM := '">Films</a></td>';
i := pos(INI,Pag); //alterado
if (i > 0) then begin
nline:=nline+1;
Line := TextBetween(pag,INI,FIM);
nome_filme := TextBetween(Line,'false;">',' </');
url := Address+TextBetween(pag, '<td><a href="/' , '">Front</');
EndPos := length(line) ;
nome_filme := IntToStr(nLine) + ' - ' + nome_filme;
If (pos('>CD</a>',url) = 0) AND (pos('>Inside<',url) = 0) AND (pos('>Back<',url) = 0) Then
Begin
PickTreeAdd(nome_filme, url);
End;
delete(Pag,i,endpos)
until (i < 1);
if PickTreeExec(Address) then begin
AnalyzeFilmPage(Address);
ShowMessage('Nada achado!')
PickListClear;
if Input('Importar Capa do allcdcovers.com', 'Escreva o nome do filme:', MovieName) then
MovieName := StringReplace(MovieName, ' ', '+');
AnalyzePage('http://www.allcdcovers.com/');
uses StringUtils1;
wl:boolean;
INI:='/download/';
FIM:='">';
i := AddExtra;
End;
Page.free;
LineNr := 0;
nLine:=0;
pag := page.text;
nline:=nline+1;
Begin
End;
until (i < 1);
PickListClear;
Is it three times the same by mistake? Or is there a reason for the three posts?
Also, when posting a script it is better to open the file in notepad, so you also have the header/properties/options, which are hidden in AMC's editor. But maybe here it is not a big problem if you didn't define options.
cluis_henrique
Re: Script for covers Allcdcovers movies
I could not delete.
