Amazon Large Pic Import Script
facts
Hello, i'm new to the forums, and never have written anything in pascal, but here is my first go at it. This should import pictures from amazon, the nice large ones
, and it stores them internally. It could be buggy, dunno, but it has worked so far for me, enjoy.
facts
Here is an updated, less buggy version.
//GETINFO SCRIPTING
//AMAZON PICTURE IMPORT (large picture)
(* Author: facts (jfacts1731@yahoo.com)
Script for the importation of pictures from amazon, FindLine code taken from
IMDB (large pic).ifs, GetToken code from SWAG archive
For use with Ant Movie Catalog 3.4.0
www.ant.be.tf/moviecatalog ··· www.buypin.com
program AmazonImport;
AmazonPage, AmazonPageNOHTML: TStringList;
TempHold, THolder, MovieName : string;
LineNr, I: Integer;
Result := -1;
if StartAt < 0 then
StartAt := 0;
Result := i;
function GetToken(aString, SepChar: String; TokenNum: Integer):String;
Token : string;
StrLen : Integer;
TNum : Integer;
TEnd : Integer;
StrLen := Length(aString);
TNum := 1;
TEnd := StrLen;
while ((TNum <= TokenNum) and (TEnd <> 0)) do
TEnd := Pos(SepChar,aString);
if TEnd <> 0 then
Token := Copy(aString,1,TEnd-1);
Delete(aString,1,TEnd);
TNum := TNum + 1;
Token := aString;
if TNum >= TokenNum then
GetToken := Token;
GetToken := '';
function AsinParse(Line : string): string;
Result := GetToken(GetToken(Line,'.',2),Chr(34),1);
if Input('IMDb Import', 'Enter the title of the movie:', MovieName) = False then
AmazonPage := TStringList.Create;
AmazonPage.Text := GetPage('http://www.amazon.com/exec/obidos/search-handle-url/index=dvd&field-title=' + StringReplace(UrlEncode(MovieName),'+', '%20'));
{* debugging stuff AmazonPageNOHTML := TStringList.Create;
AmazonPageNOHTML.Text := AmazonPage.Text;
TempHold := AmazonPageNOHTML.Text;
HTMLRemoveTags(TempHold);
AmazonPageNOHTML.Text := TempHold;
AmazonPageNOHTML.SaveToFile('d:\rips\nohtmlized.txt');
AmazonPage.SaveToFile('d:\rips\htmlized.txt'); *}
if FindLine('Amazon.com: DVD:',AmazonPage,1) <> -1 then
LineNr := FindLine('<input type="hidden" name="asin.',AmazonPage,1);
GetPicture('http://images.amazon.com/images/P/' + AsinParse(AmazonPage.Getstring(LineNr)) + '.01.LZZZZZZZ.jpg',False);
if FindLine('DVD Search Results: we were unable to find exact matches for your search for',AmazonPage,1) <> -1 then
if (FindLine('Below are results for',AmazonPage,1) <> -1) OR (FindLine('All results',AmazonPage,1) <> -1) OR (FindLine('Most popular results for',AmazonPage,1) <> -1) then
I := 1;
PickTreeAdd('Movies','');
while (i <= AmazonPage.Count-1) do
THolder := AmazonPage.GetString(i);
HTMLRemoveTags(THolder);
if (Pos('/exec/obidos/ASIN/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Buy new',AmazonPage.GetString(i)) = 0) and (Pos('Used & new from',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) then
PickTreeAdd(THolder,GetToken(AmazonPage.GetString(i),'/',5));
if (Pos('/exec/obidos/tg/detail/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Buy new',AmazonPage.GetString(i)) = 0) and (Pos('Used & new from',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) and (Pos('http://www.amazon.com',AmazonPage.GetString(i)) = 0) and (Pos('In-store Pickup',AmazonPage.GetString(i)) = 0) then
PickTreeAdd(THolder,GetToken(AmazonPage.GetString(i),'/',7));
i := i + 1;
if PickTreeExec(THolder) then
GetPicture('http://images.amazon.com/images/P/' + THolder + '.01.LZZZZZZZ.jpg',False);
WhiteRabbit
Your Script is great!
But i need the Big Pics from the german Site www.amazon.de
I've tried to change your script, but i failed.
It seems to me that the index part of the search url don't work on the german site.
How can i explorer the syntax of the search url from amazon.de?
If i use the web "frontend", i can't see the syntax.
I hope someone can help me.
WhitRabbit
PS: Sorry about my evil englich but i'm only a kraut
WhitRabbit
WhiteRabbit
I got it. Pics from Amazon.de
Here it is:
Here it is:
//GETINFO SCRIPTING
LineNr, I: Integer;
Result := -1;
if StartAt < 0 then
StartAt := 0;
Result := i;
Token : string;
StrLen : Integer;
TNum : Integer;
TEnd : Integer;
TNum := 1;
TEnd := StrLen;
if TEnd <> 0 then
TNum := TNum + 1;
Token := aString;
GetToken := Token;
GetToken := '';
AmazonPage.Text := GetPage('http://www.amazon.de/exec/obidos/search-handle-url/index=dvd-de&field-title=' + StringReplace(UrlEncode(MovieName),'+', '%20'));
if FindLine('Infos zu diesem Titel',AmazonPage,1) <> -1 then
GetPicture('http://images-eu.amazon.com/images/P/' + AsinParse(AmazonPage.Getstring(LineNr)) + '.03.LZZZZZZZ.jpg',False);
if FindLine('Wir haben keine genauen Treffer für Ihre Suche für ',AmazonPage,1) <> -1 then
if (FindLine('Die besten Treffer',AmazonPage,1) <> -1) OR (FindLine('Alle Ergebnisse für',AmazonPage,1) <> -1) then
I := 1;
if (Pos('/exec/obidos/ASIN/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Preis: EUR',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) then
i := i + 1;
GetPicture('http://images-eu.amazon.com/images/P/' + THolder + '.03.LZZZZZZZ.jpg',False);
I added "
" tags to make it more readable, try to not forget them next time ;)
