[REL] RunLocalWebServerTest
morfius
Post by morfius »
This is just a sample. Practical implementation about the idea of this post
The most simple Local Web Server is available here (extract in any folder)
The script RunLocalWebServerTest.ifs is available here (copy to AMC Script dir)
Run the RunLocalWebServerTest.csproj in SharpDev or Visual Studio.
Run AMC and add a film. Select RunLocalWebServerTest.ifs as script.
The Main Program, with comments
program RunLocalWebServerTest ;
  sRunLocalWebServer = 'RunLocalWebServer importer';
	gsBuscado, gsYear: string;
	gbRes: Boolean;
function findMovieFA(m: string; idFA: string; buscado: string; year: string; precision: string; mostrarAvisos: Boolean): Boolean;
command, parameters: string;
n: Integer;
ExpectedLines, Count: Integer;//debug
fIntercambio, fInicio: string;
aList: TStringList;
bNoFirstTime: Boolean;
	ExpectedLines := 8;
	parameters := '"' + m + '" ' + year;
	//Check External program Version
  bNoFirstTime := True;//TODO Set a Option or Parameter
	if (bNoFirstTime = False) then
		//Do something, like run without parameteres for get Version
		//aList := TStringList.Create;
		//aList.Text := GetPage('http://localhost:6969/CheckVer');
	RaiseConnectionErrors(False);//Ignore Error, Script must catch them
	aList.Text := GetPage('http://localhost:6969/RunLocalWebServerTest?Text1=' + m + '?Year=' + year + '?Text2=Value2?Text3=Value3?Text4=Value4?Text5=Value5?Text6=Value6?Text7=Value7');
	n := aList.Count;
	if aList.Count > 0 then
		parameters := aList.Text;
		for n := 0 to (aList.Count - 1) do
			parameters := aList.GetString(n);
			Count := Length(parameters);
	//check number of returned lines
	if aList.Count = 2 then
		//show controled error message from external program
		ShowError(parameters);
		//1.- Too many results
		//2.- No results for search string
		//3.- Others
		exit;//function
	if aList.Count = 1 then
	//Versión
		ShowInformation(aList.Text);
		exit;//function
	if aList.Count <> ExpectedLines then
	//Error por ¿otras causas?
	//no se pudo escribir el archivo (se ejecuta desde un medio de solo lectura)
		ShowError('Local Web Serer its not Running Or Error in Response!!');
		exit;//function
	//OK continue
	//now you have aList array with results
	//Call your Main routine here
	//YourMainRoutine(aList);
	//To Work!!
	//To Work!!
	//To Work!!
	//free memory
	aList.Free;
end;//function
	gsBuscado := GetField(fieldURL);
	if Length(gsBuscado) > 0 then
		findMovieFA(gsBuscado, '', '', '', '', False);
	gsBuscado := GetField(fieldTranslatedTitle);
	if gsBuscado = '' then
		gsBuscado := GetField(fieldOriginalTitle);
		if (GetOption('AutoSelect') = 0) or (gsBuscado = '') then
			gbRes := Input(sRunLocalWebServer, 'Pelicula:', gsBuscado);
			if (gbRes = False) then
	gsYear := GetField(fieldYear);
	findMovieFA(gsBuscado, '', '', gsYear, '', False);
One more complex implementation is available here
All files are open source and are hosted in SourceForge
That's all!
