Backup of preferences
Linus
Post by Linus »
how can i do backup of preferences?
Thanks...
kgytopi
Re: Backup of preferences
Post by kgytopi »
Linus wrote:Hi,
Thanks...
Save it the prefs.xml file
Linus
Post by Linus »
Thanks! :)
And scripts.ini if you wish to keep options selected in each script
Linus
Post by Linus »
:grinking:
