SQL export/templates feuture.
David
Post by David »
ASP/PHP Templates for importing/viewing the exported sql file would be perfect. maybe one template for each "big" db systems like mssql, mysql, postgres and access?
And a access sql export from the program. The sql syntax don't match access.
For the SQL export, I'll make a scripted export in the future version so I will be able to make several SQL exports, customized for each DBMS.
There is a sample PHP-MySQL template in a zip file in the templates folder.
I do not know ASP so I could not do anything for it :/
David
Post by David »
antp wrote:For the SQL export, I'll make a scripted export in the future version so I will be able to make several SQL exports, customized for each DBMS.
I can do the php-mysql template to a asp-mysql template if you wan't me too?
It would be nice, yes ;)
