IMDB.ifs nor working
xrigaru
Post by xrigaru »
Hi there,
I am using the latest version of Ant Movie, and the last of IMDB.ifs script, Version = 3.83.
When I search the title of a movie, the script returns me the message: HTTP / 1.1 404 not found.
I searched for an update the script to fix but can not find.
Thanks!!!
It seems to work for me, so it is either only occuring on some movies, or only with some options activated, or a problem due to your connexion or the country from which you connect (as IMDb tend to change their page on that criteria)
xrigaru
Post by xrigaru »
Thanks for responding.
Is the latest version of Ant (4.2) and the standard configuration unchanged.
I connect from Spain, and I don't usually have problems in the network.
I have had this problem with several movies.
Can you give an example of movie title, as well as a screen capture of your options, just in case of?
