Easy to edit: template for TV display & template for myH
Graal_CPM
Post by Graal_CPM »
1/ A template designed to be viewed on a TV (big letters, dark non-smeering colors)... and to be VERY easily edited to change colors, language, etc... (edit the CSS file)
1.1/ HTML File (to be used as indiv in AMC) :
<html>
<head><link rel="stylesheet" href="myAMC.css" TYPE="text/css"></head>
<body class="bgmain"><table border="0" cellpadding="5" cellspacing="0">
<tr>
 <td><table border="0" cellspacing="4" cellpadding="4">
<tr>
 <td colspan="3" class="title">$$ITEM_FORMATTEDTITLE2</td></tr>
<tr>
 <td rowspan="9" width="10%" class="tag">
 <a href="$$ITEM_URL"><img src="$$ITEM_PICTUREFILENAME" border=0 width="215" height="308"></a></td>
 <td class="field">Rating : </td>
 <td class="tag"><img src="rating$$ITEM_RATING.gif"> (07/10) </td></tr>
 <td class="field">Director :</td>
 <td class="tag">$$ITEM_DIRECTOR</td></tr>
 <td class="field">Country :</td>
 <td class="tag">$$ITEM_COUNTRY</td></tr>
 <td class="field">Genre :</td>
 <td class="tag">$$ITEM_CATEGORY</td></tr>
 <td class="field">Year :</td>
 <td class="tag">$$ITEM_YEAR</td></tr>
 <td class="field">Language :</td>
 <td class="tag">$$ITEM_LANGUAGES</td></tr>
 <td class="field">Subtitle :</td>
 <td class="tag">$$ITEM_SUBTITLES</td></tr>
 <td class="field">Lenght :</td>
 <td class="tag">$$ITEM_LENGTH</td></tr>
 <td class="field">Media :</td>
 <td class="tag">$$ITEM_TYPE #$$ITEM_NUMBER</td></tr>
</table>
 <tr class="field">
 <td>Description :</td></tr>
 <tr class="tag">
 <td>$$ITEM_DESCRIPTION</td></tr>
 <tr class="field">
 <td>Actors :</td></tr>
 <tr class="tag">
 <td>$$ITEM_ACTORS</td></tr>
 <tr class="field">
 <td>Comments :</td></tr>
 <tr class="tag">
 <td>$$ITEM_COMMENTS</td></tr>
</table>
<table width="100%" border="0" cellspacing="4" cellpadding="4">
<tr>
 <td class="field">Video Format :</td>
 <td class="tag">$$ITEM_VIDEOFORMAT</td>
 <td class="field">Audio Format :</td>
 <td class="tag">$$ITEM_AUDIOFORMAT</td></tr>
<tr>
 <td class="field">Resolution :</td>
 <td class="tag">$$ITEM_RESOLUTION</td>
 <td class="field">Framerate :</td>
 <td class="tag">$$ITEM_FRAMERATE</td></tr>
<tr>
 <td class="field">Size (Mb) :</td>
 <td class="tag">$$ITEM_SIZE</td>
 <td class="field">Disks :</td>
 <td class="tag">$$ITEM_DISKS</td></tr>
</table>
</td>
</tr>
</table>
<div align="center">
<form><input class="css" type="button" value="Close" onClick="window.close()"></form></div>
</body>
</html>
You need to get some gif with filename ratingX.gif (X from 0 to 10) from another template.
1.2/ CSS file (to be copied into your target directory for exporting) :
.About {Graal_CPM myAMC template 05-April-2003}
.bgmain {
 background-attachment: fixed;
 background-image: url(bkgd01_800x600.jpg)
.title {
 font-family: Arial, Helvetica, sans-serif;
 font-size: 24pt;
 font-style: normal;
 background-color: #330066;
 text-align: center;
 body {
 scrollbar-3d-light-color: #800080;
 scrollbar-arrow-color: #666666;
 scrollbar-base-color: #666666;
 scrollbar-dark-shadow-color: #FFFFFF;
 scrollbar-face-color: #370037;
 scrollbar-highlight-color: #555555;
 scrollbar-shadow-color: #330066;
 color: #FFF0FF;
 font-weight: bold
.field {
 font-weight: bold;
 font-size: 14pt;
 background-color: #370037
.tag {
 font-size: 16pt;
 font-weight: bold;
.cellpix {
 clip:    rect(   );
 height: 0px; width: 0px}
input.css {
font-family:arial;
sans-serif;
font-size:14pt;
font-weight:bold;
background:#370037;
color:#FFF0FF;
border-width:1px;
border-style:solid;
width:96px;
height:30px;
cursor:hand;
padding:0px}
2/ Here is a template to generate a metadata file for myHTPC :
$$ITEM_BEGIN
[$$ITEM_NUMBER]
title=$$ITEM_FORMATTEDTITLE2
subtitle=$$ITEM_LENGTH Minutes $$ITEM_CATEGORY by $$ITEM_DIRECTOR
overview=$$ITEM_DESCRIPTION
produced=$$ITEM_TYPE #$$ITEM_NUMBER
rating=
review=$$ITEM_RATING
images=$$ITEM_PICTUREFILENAME
chain="Movie details",$$ITEM_FILEINDIV
category=Country,"$$ITEM_COUNTRY"
category=Director,"$$ITEM_DIRECTOR"
category=Genre,"$$ITEM_CATEGORY"
category="Lang & Sub","$$ITEM_LANGUAGES $$ITEM_SUBTITLES"
category=Year,$$ITEM_YEAR
category=Media,"$$ITEM_TYPE"
category="Date added",$$ITEM_DATEADD
$$ITEM_END
To use it :
-Export under the name myAMC.html.
-Rename the generated myAMC.html to myAMC.my.
-In myHTPC, create a new Media.
-General tab : grouping method=single metadata file, filename=c:\path\myAMC.my, uncheck ALL cache settings, play with other settings as you wish.
-Player : Excecutable=c:\whateverpath\iexplorer.exe, parameters=-k, Current dir=where you exported your catalog
It displays the whole movie database in myHTPC, allowing to sort by country, director, genre, etc. A click on "play" pops up Explorer with indiv template and all details about the movie in kiosk mode (no borders, ctrl-W to close, up/down arrows to scroll, alt-left/right arrows to go back/forward).
A click on the picture launch the associated URL on the internet. If no URL is available it will display windows files (!), sorry it's not very clean, just close the window with ctrl-W.
Enjoy!
thanks, I will try to not forget to include it with the program ;)
Graal_CPM
Post by Graal_CPM »
J'en serais très honoré :hihi: !
By the way the bkgd01_800x600.jpg inluded in this template comes from this site : http://www.webpromotion.com/htp/htpcbackgrounds.html.
It's free and matches the colors of the template quite well.
But... you can get 100.000+ backgrounds and gfx stuff at http://www.wincustomize.com/
This site just rocks if you take time to dig in.
Nicmae
No image on my catalog
Post by Nicmae »
I discover myHTPC, thanks it's so wonderfull! Windows Media Center suck ;-)
Juste a little question, i haven't the pic with my film.... can you help me?
Thanks a lot!
