Regular expression replacement doesn't work
viplexke
Post by viplexke »
I'd like to rename folders in a structure. Problem:
Regular expression action doesn't rename my folders, although a replacement is shown in the preview textbox at the bottom (Preview in the Files pane doesn't show any change)
FYI: String replacement does work for the same folder structure.
Here's my regexp pane:
http://prntscr.com/4ahe6v
Does it show an error message in the "Log" page, once you run that?
