Print Templates
Print Templates
I try to custom one Template to print my movies, but want to know if it's possible to put two movies in one line, I mean if it's possible to create two "master data" in the same line. My objective is to get more movies in the same page, in two columns...
There is a sample template with 3 columns.
Actually you have to go to File -> Page Options -> Options, and enter a number of columns.
Thanks... :)
Sorting of the report
Is there a way to sort the report? I can't make out what sort order it is currently using. Seems to the same sort for all reports, just don't know what field it is using or if I can change it.
Sorting of the report - nevermind
Nevermind... Found it.
