Writing credits field
palantir
Post by palantir »
As i already said, the program is just great.
i have a few suggestions:
- including a Writing credits field would be very good. i like to know who wrote the film and i believe it's a really important information
- when exporting the DB to html the Director field could also be included
for now it's all;)[/b]
For the HTML export you can modify yourself the template if you want to include more fields ;)
palantir
Post by palantir »
ok, thanks for the tip...
I'll try to do that, although I don't know much of html...
so if i could get any help as how to do that, it would be great
as for the writing credits field, try to include it in future developments as i think it's very important in a movie to know ho wrote it :D
