Not import from movie file
dmiszkur
Post by dmiszkur »
Hi.
I tried many times to import information from file to ant movie catalog. After select file and click ok, there are no information import. it`s like nothing happen.
File was burned on dvd and from there tried to import. When i copy this file to local disk and after that import from local disk, information about file had just showed in inputs.
File on dvd doesn`t have information about create time, modyfing time and last used time. On local disk this information exists.
version of ant movie catalog 4.2.0
Did someone has the same problem and know how to import file?
