Thanks for the program and 1 suggestion
Reh
Post by Reh »
hi man
i can just say wow
your program has a stable and good database syste, it looks good, has many _use_full functions, a good working internet information update system and it is still free
i hope you will stay on this way
i have only 1 suggestion - can you add a online script import system? casue users write scripts here in forum and everytime i have top create my own script and insert it and so on, or i dont see updates on scripts
and next issue, i modify the scripts by myself, is there an option to save this scripts while installing, to update all other scripts but left my edited scripts alive?
i do this actually with diff, but its a little bit work :)
i know if i say "its a little bit work for me" its even more work for you, but perhaps some other people expect me need such a feature, too
a happy amc user
--Reh--
Usually I add the scripts posted here in the next version of the program.
Maybe that in the future I may make a "script repository" site that the program can check, but it may require much bandwidth, so I am not sure it is possible to do with the current hosting that I have for my site.
When you update, only files that came with the program are overwritten/modified. If you modify files you can change their names so they are not modified by the installer.
