[UPD] [ITA] FilmTV.it
Piccola correzione: non estraeva il titolo tradotto.
Small correction: it didn't extract translated title.
Authors=Fulvio53s03 (based on Fiezul, PIvello, Valerino & others works).
Title=FilmTV
Site=www.Film.TV.it
Language=IT
Version=3.3    15.6.2014
Requires=3.5.1
Comments=
License=
RequiresMovies=1
[Parameters]
program FilmTVIt;
  StringUtils7552;   // Script needs external unit StringUtils7552.pas in scripts folder !
  //Query constants
  UrlBase = 'http://www.film.tv.it';
  QueryBase = UrlBase + '/cerca/?q=';
  QueryFilm = UrlBase + '';
  //Search page constants
  Apice       = #39;
  cStartFilmUrl = '<a class="pic" href="'; // ID start marker   //fs2014.04.21
  cEndFilmUrl = '">';                       // ID end marker  //fs2014.04.21
  cStartTitle = '<img alt="';                      // Title start marker  //fs2014.04.21
  cEndTitle = '" src="';                     // Title end marker  //fs2014.04.21
  //Film page constants
  cStartTranslTitle = '<div class="wrap-head">';                  // Translated title start marker
  cEndTranslTitle = '<div class=';                   // Translated title end marker
  cStartOrigTitle = '[<i>';     // Original title start marker
  cEndOrigTitle = '</i>';                   // Original title end marker
  cStartImgLink_ext = '<figure class="locandina">';               // Image start marker
  cStartImgLink_int = '<img src="';               // Image start marker
  cEndImgLink_int = '"';   // Image end marker
  cEndImgLink_ext = '</figure>';   // Image end marker
  cStartListItem = ', ';
  cEndCountry = '<a href="/film/anno';
  cEndListItem = ', ';                           // Generic field marker
  cStartCategory = '/">';                        // Category start marker
  cEndCategory = '</a>';                         // Single Director end marker
  cEndDirectors = '</p>';                        // Directors end marker
  cStartDirector = 'Regia di';                   // Single Director start marker
  cEndDirector = '</p>';                         // Single Director end marker
  cStartCast = 'Con</span>';                     // Cast start marker
  cEndCast = '<strong>';                         // Cast end marker
  cStartActor = '">';                            // Actor start marker
  cEndActor = '</a>';                            // Actor end marker
  cStartDesc = '<h1>Trama</h1>';                 // Description start marker  //FS2012-11-11
  cStartComm = '<blockquote>';                   //fs2013-02-11
  cEndComm = '</blockquote>';                    // Comment end marker
  cStartURL='<li id="sel"><a href="/';
  cEndURL='" title="scheda"';
  InitYear = '<h2>';             //fs2014.04.22
//  EndYear = '</h2>';            //fs2014.04.22
  EndYear = ', con ';            //fs2014.06.03
  searchUrl, MovieUrl, MovieName, OriginalStr, TranslatedStr, File_name, PageStr:  string;
  MoviesFound: integer;
// PAGE PACKING (remove extra spaces, tabs & CR) by Pivello
// IN:  page Url     (string)
// OUT: compact page (string)
  TmpPageStr: string;
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  TmpPageStr := '';
  Page.Text := GetPage(Url);
  for n := 0 to Page.Count - 1 do
    if CharPos = 0 then
    if CharPos <> 0 then
        Temp := copy(PackedPage, 1, CharPos - 1);
  result := PackedPage;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure SetMovieFields (htmlStr: string);
  i, h, m: integer;
  Duration, Description, Cast, TempStr, TempImg, hh, mm,temp: string;
  tempDirector, director: string;
  PosParAperta, PosParChiusa: integer;
  imageLink: string;
  sep1, sep2: string;
  SaveHtmlstr, tempvar : string;
  dati_generali, Title_orig, Paese, Anno, Categoria, durata : string;
  // General movie description fields
  anno := '';
  TranslatedStr := TextBetween(htmlStr, cStartTranslTitle, cEndTranslTitle);
  TranslatedStr := TextBetween(TranslatedStr, '<h1>', '</h1>');
  if length(Translatedstr) < 1 then
    TranslatedStr := TextBetween(TranslatedStr, '<h1 >', '</h1>');
  SetField(fieldTranslatedTitle, AnsiMixedCase(AnsiLowerCase(TranslatedStr), ' '));    //Titolo Tradotto
//Dati Generali (tit.orig, paese, anno, genere, durata ecc.)
  Dati_generali := TextBetween(htmlStr, '<div class="wrap-head-content cf"', '<div class="visione cf">');
  Title_orig    := FullTrim(TextBetween(Dati_generali, '<li><h2>', '</h2></li>'));
  SetField(fieldOriginalTitle, Title_orig);
  if length(Title_orig) > 0 then
     Paese := TextBetween(Dati_generali, '</li> <li>', '<time>');
     Anno := TextBetween(Dati_generali, '<time>', '</time>');
     Categoria := fulltrim(Textbetween(Dati_generali, '<span>Genere:</span>', '</li>'));
     durata := fulltrim(Textbetween(Dati_generali, '<span>durata</span>', '</li>'));
     Paese := TextBetween(Dati_generali, '<li>', '<time>');
  SetField(fieldCountry, Paese);
  SetField(fieldYear, Anno);
  SetField(fieldCategory, Categoria);
  temp := Textbefore(durata, apice, '');
  SetField(fieldLength, temp);
//Get Director
  temp:= TextBetween(htmlstr, cStartDirector,cEndDirector);
  HTMLRemoveTags(temp);
  HTMLDecode(temp);
  temp:= fulltrim(temp);
  setfield(FieldDirector, Temp);
//Get Actors
  temp:= TextBetween(htmlStr, cStartCast,cEndCast);
  HTMLRemoveTags(temp);                       //fs 2012-04-03
  HTMLDecode(temp);
  SetField(fieldActors, FullTrim(temp))
//Get comments
  SaveHtmlstr:= htmlstr;
  temp:= Textbetween(htmlStr, cStartDesc, cEndDesc);
  HTMLDecode(temp);
  SetField(fieldDescription, FullTrim(temp));
  temp := TextBetween(HtmlStr, cStartComm, cEndComm);
  HTMLDecode(temp);
  SetField(fieldComments, FullTrim(temp));
  htmlstr:= SaveHtmlstr;
  //Get URL
  SetField(fieldURL, movieurl);
  //Get image     http://ftv01.stbm.it/imgbank/GALLERYXL/R201404/the_english_teacher_poster_ita.jpg
  imagelink := TextBetween(htmlStr, cStartImgLink_ext, cEndImgLink_ext);
  imagelink := TextBetween(imagelink, cStartImgLink_int, cEndImgLink_int);
//  setfield(FieldSubTitles, imagelink);
//  if imagelink <> 'http://www.film.tv.it/imgbank/DUMMY/no_locandina.jpg'  then
    if imagelink <> 'http://ftv01.stbm.it/imgbank/DUMMY/no_locandina.jpg'  then
       GetPicture2(imagelink, movieurl);
//     GetPicture(imagelink);
//Returns a text field from an input string strIn (pagestr)
//delIn and delOut: text field delimiters
function getTextDelimited(lIn:string; lOut:string;Var strIn:string): string;
  StartPos: integer;
  len:integer;
  tempStr: string;
  lgth_pagestr: integer;
  lgth_pagestr:= length(strIn);
  StartPos := pos(lIn, strIn);
  if startPos<>0 then
    StartPos:=StartPos+Length(lIn);
    tempStr:= copy(strIn,StartPos,StartPos+length(strIn));
    len := pos(lOut, tempStr);
     if len=0 then
      result:=''
      result := copy(strIn, StartPos, len-1); // get Text Out
  Delete(strIn, 1, StartPos-1 + len-1 + length(lOut)-2);
    result := '';
  HTMLDecode(result);
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
procedure PopulatePickTree();
  filmUrl, partialUrl: string;
  filmTitle, filmYear: string;
  StartPos, EndPos: integer;
  Lgth_pagestr: integer;
//      PickTreeAdd('Risultati ricerca per "' + File_name + '":', '');
      PickTreeAdd('Risultati ricerca per "' + getfield(fieldFilePath) + '":', '');
        partialUrl:= getTextDelimited(cStartFilmUrl,cEndFilmUrl,PageStr);
        filmUrl:=UrlBase + partialUrl;
        filmTitle:=getTextDelimited(cStartTitle,cEndTitle,PageStr);
        filmYear:=getTextDelimited(InitYear, EndYear,PageStr);
//fs20140603        filmYear:= copy(filmYear, 1, 42);
        filmYear:= '   ' + '(' + filmYear + ')';
        filmTitle := filmtitle + ' ' + filmYear;
        MoviesFound := MoviesFound + 1;
        if partialUrl<>'' then
          PickTreeAdd(filmTitle, filmUrl);
      until(partialUrl='');
// IN:  html of search page (string)
// OUT: movie url
function analyzePage(htmlSearchPage: string): string;
  FilmId: string;
  result:='';
  if pos('Non ho trovato nulla!', htmlSearchPage) > 0 then
      PopulatePickTree();
      if  MoviesFound > 1 then
          if not PickTreeExec(result) then
                MoviesFound := 0;
      if  MoviesFound <= 1 then
//          begin
//          if not PickTreeExec(result) then
             exit;                    //Select one title
//          end;
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,5,1) then
      if (TranslatedStr <> '') then
        MovieName := TranslatedStr
        MovieName := OriginalStr;
      File_name := MovieName;
      if(Input('Film.TV.It', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
          //Get search page
          MoviesFound := 0;
// http://www.filmtv.it/cerca/?q=dalle+9+alle+5+orario+continuato
//          searchUrl := QueryBase + UrlEncode(MovieName);
            searchUrl := QueryBase + Stringreplace(MovieName, ' ', '+');
          PageStr := RemoveExtraChars(searchUrl);
          PageStr := UTF8Decode(PageStr);
          //Analyze search page and get movie url (user choice)
          MovieUrl:=analyzePage(PageStr);
          // Get movie page
          if  MoviesFound = 0 then
          Pagestr := Stringreplace(Pagestr, '’', '´');
          //Analyze movie page and set movie fields
          SetMovieFields(PageStr);
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.1)');
rosbert
Re: [UPD] [ITA] FilmTV.it
Post by rosbert »
fulvio53s03 wrote: PickTreeAdd('Risultati ricerca per "' + getfield(fieldFilePath) + '":', '');
Ciao a me funziona commentando la riga quotata altrimenti dà errore di variabile non dichiarata (fieldFilePath)
.... strano.... appena provato col film "adam resurrected" funziona regolarmente.
Le versioni delle componenti di AMC sono:
MovieCatalog.exe : version 4.2.0.1 (08/07/2013 21.30.12)
AMCExchange.dll : version 1.7.0.1 (08/07/2013 21.30.18)
AMCReport.exe : version 1.7.0.1 (08/07/2013 21.30.28)
MediaInfo.dll : version 0.7.61 (21/10/2012 18.29.06)
lo script è la versione 3.3 del 15.6.2014....
Credo che tu usi una versione anteriore in cui il campo FilePath non esisteva.
Verifica e fammi sapere, per cortesia.
:hum:
rosbert
Post by rosbert »
:hum:
moviecatalog.exe : versione 4.1.2.2 (creata il 26/12/2012 11.25.10)
AMCExchange.dll : versione 1.6.0.1 (creata il 26/12/2012 11.25.28)
AMCReport.exe : versione 1.5.0.1 (creata il 26/12/2012 11.25.36)
MediaInfo.dll : versione 0.7.59 (creata il 08/08/2012 13.32.54)
Ecco, appunto.... devi aggiornare AMC e anche lo script.
As I said.... update AMC and script, too
viewtopic.php?t=5836
