Name Variable My Rating
al0203
Post by al0203 »
Which is the name for the variable My Rating?
When I look in the programs help it saids UserRating, but when I try to use it, it returns me an error.
In the old version I had created a custom variable call Nota (Real 1) and I´m trying to copy this values to the new field My Rating.
When you import an AMC file, is it the possibillity to change the variable of a colum data? When you import from an excel you can chose which colum goes with which variable.
Raoul_Volfoni
Post by Raoul_Volfoni »
al0203 wrote:Which is the name for the variable My Rating?
It's fieldUserRating.
al0203 wrote:In the old version I had created a custom variable call Nota (Real 1) and I´m trying to copy this values to the new field My Rating.
If the tag of your custom field is also Nota, this little script should do the trick
program Nota_to_UserRating;
SetField(fieldUserRating,GetCustomField('Nota'));
If the tag is different, just change Nota by the value of your custom field tag.
al0203 wrote:When you import an AMC file, is it the possibillity to change the variable of a colum data? When you import from an excel you can chose which colum goes with which variable.
You have to click on column headers to assign fields to them.
