Hi guys,
now that 4.2.0 is officially out, I'd like to ask you to do couple of fixes for IMDb script, if possible:
1. Add Writer, so that it automatically saved during import
2. Add Composer, so that it automatically saved during import
3. Fix IMDb Trivia, so that strings like "X of X found this interesting" or "Is this interesting?" is removed when saving trivia
4. Round Rating when "Do not display decimals" is used, so that movie with rating 3,9 won't be saved as 3.
5. Certification should be put to the correct field, since we have one now.
Thanks a lot,
Elman
IMDb script - add writer, composer
elman
The language used is indeed very close to Pascal/Delphi
(it uses mostly the same syntax and functions, the differences are minor)
In the help file, in Technical info -> Script files creation, you can find the detail of functions added to the script engine especially for AMC, including the regex functions.
elman
elman
I finished the script. It will only work with AMC 4.2.0 and hopefully I didn't break any functionality.
Change list:
- Writer is automatically imported
- Composer is automatically imported
- Fixed IMDb Trivia, so that strings like "X of X found this interesting" or "Is this interesting?" is removed
- Added Rating rounding so that movie with rating 3,9 won't be saved as 3 but rather 4. For this you will have to set script option RoundRating to 1.
- Certification is put to the correct field
- Removed empty space after Original title if translation exists
- Removed empty space after description if IMDB trivia exists
- All directors are now imported
- Removed extra line if CommentType=0
Change list:
Authors=Antoine Potten, KaraGarga, baffab, Thermal Ions, bad4u, Sancho, Joe, cage, Elman
Title=IMDB
Description=Import data & picture from IMDB (optional image from Amazon)
Site=us.imdb.com
Language=EN
Version=3.86
Requires=4.2.0
Comments=Based on the script made for version 3.3/3.4 by Antoine Potten, Danny Falkov, Kai Blankenhorn, lboregard, Ork, Trekkie, Youri Heijnen
RequiresMovies=1
ActorsLayout=2|0|0=Only actor names, separated by commas|1=Only actor names, separated by linebreaks|2=Actors names with character names between parenthesis separated by commas|3=Actors names with character names between parenthesis separated by linebreaks|4=Actor names like on IMDB page, with "...." and separated by linebreaks
AllActors=1|0|0=Only import actors from main page (does not work if you import producer name)|1=Import all possible actors|2=Import 10 first actors (does not work with ActorLayout=4)
AspectRatio=1|1|0=Do not import picture aspect ratio|1=Import picture aspect ratio to video format field|2=Import picture aspect ratio to resolution field
Awards=2|0|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not display any window, takes the first movie found|2=Same as 1, but it uses the URL field if available to update movie information
CommentType=0|0|0=Standard Type (Only one comment from main page)|1=Detailed Type (10 most useful comments from comments page)|2=No user comment, clear current field contents|3=No user comment, keep current field contents (may cause problem for multiple imports on the same movie if other options append text to the comment field)
ConvertToASCII=0|0|0=Do not change special characters and accents.|1=Replace special characters and accents by basic ASCII characters
DescriptionSelection=0|0|0=Take the short summary, from main page (faster)|1=Show a list of available summaries|2=Take the longest summary
EpisodeTitleSearch=0|0|0=Use "Find more" button on results list for next result pages if available (default)|1=Use "Find more" button on results list for episode title search instead
GetTagline=1|1|0=Do not get tagline|1=Put it in Description field, before the summary|2=Put it in the Comment field, before the comments
HideAkaTitles=0|0|0=Show 'aka' titles on result list (= other titles for the film)|1=Hide 'aka' titles on result list
ImageKind=3|3|0=No image|1=IMDB small image, from the main movie page, no image if none available|2=IMDB small image, from the main movie page, "No Poster Available" if none available|3=IMDB large image, from link on main movie page, else small image, else "No Poster Available"|4=Cover from "Merchandising Link" page, else "DVD detail" page, else small image|5=Cover from "DVD detail" page, else "Merchandising Link", else small image
MPAA=2|0|0=Do not import MPAA rating|1=Import MPAA rating to MediaType|2=Append MPAA rating and info to Comments
MultipleValuesAudioFormat=1|1|0=Only take first value for Audio Format|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Audio Format / Sound Mix
MultipleValuesCategory=1|1|0=Only take first value for Category|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Category
MultipleValuesCountry=1|1|0=Only take first value for Country|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Country
MultipleValuesLanguages=1|1|0=Only take first value for Languages|1=Take full list, separated by commas|2=Take full list, separated by slashes|3=Do not import Languages
PopularSearches=1|1|0=Do not use the popular searches page, directly show full search results|1=Show popular searches first, I'll click on "Find more" if needed (much faster)
RoundRating=0|0|0=Do not round Rating|1=Round Rating to whole number
Trivia=0|0|0=Do not import trivia|1=Import short trivia to Description field, after the summary|2=Import short trivia to Comments field, after the comments|3=Import full trivia to Description field, after the summary|4=Import full trivia to Comments field, after the comments
UserRatings=0|0|0=Import value to ratings field only (default)|1=Import value and number of votes to Media Type field|2=Import value and number of votes to comments field
[Parameters]
program IMDB;
StringUtils1;
// ***** Manually set UserCountry to your required Classification Country below *****
//UserCountry = '';
{ Delete the line above and remove the "//" in front of one the
following lines, or add your country if it is not listed }
UserCountry = 'USA';
//UserCountry = 'Canada';
//UserCountry = 'Mexico';
//UserCountry = 'Brazil';
//UserCountry = 'Argentina';
//UserCountry = 'Australia';
//UserCountry = 'India';
//UserCountry = 'Italy';
//UserCountry = 'Spain';
//UserCountry = 'Portugal';
//UserCountry = 'France';
//UserCountry = 'Germany';
//UserCountry = 'Netherlands';
//UserCountry = 'UK';
//UserCountry = 'Ireland';
//UserCountry = 'Finland';
//UserCountry = 'Norway';
//UserCountry = 'Sweden';
//UserCountry = 'Switzerland';
PopularTitleSearchURL = 'http://www.imdb.com/find?s=tt&q=';
FullTitleSearchURL = 'http://www.imdb.com/find?s=tt&exact=true&q=';
EpisodeTitleSearchURL = 'http://www.imdb.com/find?s=ep&q=';
MovieURL: string;
MovieNumber: string;
UpdateFile: TStringList;
function ConvertToASCII(AText: string): string;
Result := AText;
if GetOption('ConvertToASCII') = 1 then
Result := Cp1252ToASCII(AText);
// ***** analyzes IMDB's results page that asks to select a movie from a list *****
PageText: string;
Value: string;
PageText := ConvertToASCII(GetPage(Address));
if pos('<title>Find - IMDb', PageText) = 0 then
AnalyzeMoviePage(PageText)
ShowMessage('No movie found for this search.');
Exit;
Value := TextBetween(PageText, '<h1 class="findHeader">Displaying', '</h1>');
if Value <> '' then
HTMLRemoveTags(Value);
HTMLDecode(Value);
PickTreeAdd(UTF8Decode(Value), '');
Value := TextBetween(PageText, '<table class="findList">', '</table>');
PageText := RemainingText;
AddMovieTitles(Value);
Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
if Value <> '' then
PickTreeMoreLink('http://www.imdb.com' + Value);
if GetOption('EpisodeTitleSearch') > 0 then
PickTreeMoreLink(EpisodeTitleSearchURL + UrlEncode(MovieName));
AnalyzeResultsPage(Address);
Value := TextBetween(PageText, '<td class="primary_photo">', '<img src');
if Value <> '' then
AnalyzeResultsPage('http://www.imdb.com' + TextBetween(Value, '<a href="', '"'));
// ***** adds the movie titles found on IMDB's results page *****
Value: string;
Address: string;
Result := False;
Value := TextBetween(List, '<td class="result_text">', '</td>');
if GetOption('HideAkaTitles') = 1 then
Value := StringReplace(Value, TextAfter(Value, '<br/>aka'), '')
Value := StringReplace(Value, 'aka', ' | aka');
List := RemainingText;
while Value <> '' do
Address := TextBetween(Value, '<a href="/title/tt', '/');
Address := Address + '/combined';
HTMLDecode(Value);
PickTreeAdd(UTF8Decode(Value), 'http://www.imdb.com/title/tt' + Address);
Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
Value, Value2, Value3, FullValue, originalTitle: string;
p, Count: Integer;
MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/');
if MovieNumber = '' then
MovieNumber := TextBetween(PageText, '<input type="hidden" name="auto" value="legacy/title/tt', '/combined"');
MovieNumber := TextBetween(PageText, '<link rel="canonical" href="http://www.imdb.com/title/tt', '/');
// if ((GetOption('AllActors') = 1) or (GetOption('Producer') = 1)) and (Pos('<div id="tn15" class="maindetails">', PageText) > 0) then
// PageText := ConvertToASCII(GetPage('http://www.imdb.com/title/tt' + MovieNumber + '/combined'));
if Pos('/combined"', TextBetween(PageText, '<link rel="canonical"', '/>')) = 0 then
MovieURL := 'http://imdb.com/title/tt' + MovieNumber;
// URL
if CanSetField(fieldURL) then
SetField(fieldURL, MovieURL);
// OriginalTitle & Year
if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
originalTitle := TextBefore(PageText, '<i>(original title)', '<span class="title-extra">');
HTMLDecode(originalTitle);
Value := TextBetween(PageText, '<title>', '</title>');
// showmessage(originalTitle);
// showmessage(value);
if (originalTitle <> '') and CanSetField(fieldOriginalTitle) then
SetField(fieldOriginalTitle, FullTrim(originalTitle));
p := Pos(' (1', Value);
if p = 0 then
p := Pos(' (2', Value);
Value2 := Copy(Value, 0, p-1);
Value := Copy(Value, p+2, Length(Value));
HTMLDecode(Value2);
if (originalTitle = '') and CanSetField(fieldOriginalTitle) then
SetField(fieldOriginalTitle, FullTrim(Value2));
if Pos('/', Value) > 0 then
Value2 := TextBefore(Value, '/', '')
Value2 := TextBefore(Value, ')', '');
SetField(fieldYear, Value2);
// Picture
if CanSetPicture then
case GetOption('ImageKind') of
2: if not ImportSmallPicture(PageText) then
ImportPictureNotAvailable(PageText);
3: if not ImportLargePicture(PageText) then
4: if not ImportMerchandisingPicture then
if not ImportDvdDetailsPicture then
ImportSmallPicture(PageText);
5: if not ImportDvdDetailsPicture then
// Director
Value := TextBetween(PageText, 'Directed by</a></h5>', '</table>');
FullValue := '';
Value2 := TextBetween(Value, '<a href="/name/', '</a>');
while Value2 <> '' do
Value := RemainingText;
Value2 := TextAfter(Value2, '">');
if FullValue <> '' then
FullValue := FullValue + Value2;
HTMLDecode(FullValue);
// Actors
Value := FullTrim(TextBetween(PageText, '<table class="cast">', '</table>'));
if Value <> '' then
FullValue := '';
Count := 0;
case GetOption('ActorsLayout') of
0, 1:
while Pos('<tr', Value) > 0 do
Value2 := TextBetween(Value, '<tr', '</tr>');
if Pos('rest of cast', Value2) > 0 then
Continue;
TextBefore(Value2, '</td>', '');
Value2 := FullTrim(TextBetween(Value2, '<td class="nm">', '</td>'));
HTMLRemoveTags(Value2);
if Value2 <> '' then
Count := Count + 1;
if (Count = 15) and (GetOption('AllActors') = 0) then
if (Count = 10) and (GetOption('AllActors') = 2) then
2, 3:
Continue;
Value2 := FullTrim(TextBetween(RemainingText, '"char">', '</td>'));
FullValue := FullValue + ' (as ' + Value2 + ')';
Count := Count + 1;
4:
FullValue := Value;
FullValue := StringReplace(FullValue, ' <tr><td align="center" colspan="4"><small>rest of cast listed alphabetically:</small></td></tr>', '');
FullValue := StringReplace(FullValue, '> <', '><');
FullValue := StringReplace(FullValue, '</tr>', #13#10);
HTMLRemoveTags(FullValue);
0, 2:
FullValue := StringReplace(FullValue, #13#10, ', ');
// Composer
if CanSetField(fieldComposer) then
Value := TextBetween(PageText, 'Music by</a></h5>', '</table>');
FullValue := '';
SetField(fieldComposer, FullValue);
//Country
SetField(fieldCountry, ImportList(PageText, GetOption('MultipleValuesCountry'), '/country/'));
//Category
SetField(fieldCategory, ImportList(PageText, GetOption('MultipleValuesCategory'), '/Genres/'));
// Language
if CanSetField(fieldLanguages) then
SetField(fieldLanguages, ImportList(PageText, GetOption('MultipleValuesLanguages'), '/language/'));
// Audio Format
if CanSetField(fieldAudioFormat) then
SetField(fieldAudioFormat, ImportList(PageText, GetOption('MultipleValuesAudioFormat'), '/search/title?sound_mixes='));
// Aspect Ratio
Value := '';
Value := TextBetween(PageText, '<h5>Aspect Ratio:</h5>', '</div>');
if Pos('<p>', Value) > 0 then
Value := TextBetween(Value, '<p>', '</p>');
if Pos('<a ', Value) > 0 then
Value := TextBefore(Value, '<a ', '');
HTMLDecode(Value);
Value := FullTrim(Value);
Value := StringReplace(Value, ', more', '');
Value := StringReplace(Value, ', (more)', '');
Value := StringReplace(Value, ' more', '');
if (CanSetField(fieldVideoFormat)) and (GetOption('AspectRatio') = 1) then
SetField(fieldVideoFormat, Value);
if (CanSetField(fieldResolution)) and (GetOption('AspectRatio') = 2) then
SetField(fieldResolution, Value);
// Description
if CanSetField(fieldDescription) then
Value := TextBetween(PageText, '<h5>Plot:</h5>', '</div>');
if Value = '' then
Value := TextBetween(PageText, '<h5>Plot Summary:</h5>', '</div>');
Value := StringReplace(Value, '<div class="info-content">', '');
Value := StringReplace(Value, Textbetween(Value, '| <a class="tn15more inline" href="synopsis">', '</a>'), '');
Value := StringReplace(Value, Textbetween(Value, '<a class="tn15more inline" href="synopsis">', '</a>'), '');
Value := StringReplace(Value, '| <a class="tn15more inline" href="synopsis"></a>', '');
Value := StringReplace(Value, '<a class="tn15more inline" href="synopsis"></a>', '');
Value := StringReplace(Value, '»', '');
if (Value = #13#10 + #13#10) or (Value = #13#10) then
Value := '';
if (GetOption('DescriptionSelection') = 0) and (Pos('<a class="tn15more inline"', Value) > 0) then
Value := TextAfter(Value, #13#10);
if Value <> '' then
SetField(fieldDescription, ImportSummary(Value));
// Length
Value := TextBetween(PageText, '<h5>Runtime:</h5>', '</div>');
Value := TextBefore(Value, ' min', '');
if Value <> '' then
if Pos(':', Value) > 0 then
SetField(fieldLength, TextAfter(Value, ':'))
SetField(fieldLength, Value);
// Producer
Value := TextBetween(PageText, 'Produced by</a></h5>', '</table>');
FullValue := '';
SetField(fieldProducer, FullValue);
// Writer
if CanSetField(fieldWriter) then
Value := TextBetween(PageText, 'Writing credits</a></h5>', '</table>');
FullValue := '';
SetField(fieldWriter, FullValue);
// AKA Name
FullValue := ConvertToASCII(GetPage(MovieURL+'/releaseinfo#akas'));
FullValue := TextBetween(FullValue, '<a id="akas" name="akas">', '</table>');
FullValue := RemoveSpaces(FullValue, True);
FullValue := StringReplace(FullValue, #13, '');
FullValue := StringReplace(FullValue, #10, '');
FullValue := StringReplace(FullValue, '<tr class="even">', '<tr>');
FullValue := StringReplace(FullValue, '<tr class="odd">', '<tr>');
if RegExprSetExec('</td>\s*<tr>', FullValue) then
// removing the original title
FullValue := '<tr>'+TextAfter(FullValue, '</td><tr>');
while fullvalue <> '' do
// showMessage('Analysing: '+FullValue);
// each line is a pair of translated title and country
// format: <tr><td>country</td><td>Translated title</td><tr>
value2 := TextBetween(FullValue, '<tr>', '</tr>');
// showMessage('Line: '+value2);
value := TextBetween(Value2, '<td>', '</td>');
value2 := TextAfter(Value2, '</td>');
value2 := TextBetween(Value2, '<td>', '</td>');
HTMLDecode(value2);
// showMessage('Translated: '+value+' into '+value2);
if pos(UserCountry, value) > 0 then
HTMLDecode(Value2);
SetField(fieldTranslatedTitle, FullTrim(UTF8Decode(Value2)));
FullValue := '';
else FullValue := TextAfter(FullValue, '</tr>');
if Value <> '' then
Value := StringReplace(Value, 'See more', '');
Value := FullTrim(StringReplace(Value, '<br>', ', '));
HTMLDecode(Value);
if Value <> '' then
if StrGet(Value, Length(Value)) = ',' then
Delete(Value, Length(Value), 1);
SetField(fieldTranslatedTitle, Value)
// Comments
if (GetOption('CommentType') = 1) then
//Value := TextAfter(PageText,'/rg/title-nav-item/usercomments/');
//if (Value <> '') or (Pos('href="usercomments" class="link"', PageText) > 0) then
Value2 := '';
FullValue := ConvertToASCII(GetPage(MovieURL+'/usercomments'));
FullValue := TextAfter(FullValue, 'review useful:</small><br>');
while FullValue <> '' do
Value := TextBetween(FullValue, '<b>', '<div');
//Value2 := Value2 + #13#10 + #13#10 + TextBefore(Value, '</b>', '');
Value2 := Value2 + #13#10 + #13#10 + TextBetween(Value, '">', '</a>');
Value2 := Value2 + #32+ TextBetween(Value, '<small>', '</small>');
Value2 := Value2 + #32 + 'said on ' + TextBetween(Value, '<small>', '</small>');
Value := TextBetween(Value, 'comments">', '<br>');
HtmlRemoveTags(Value);
Value2 := Value2 + #13#10 + Value;
Value := TextBetween(Value, '<p>' + #13#10, #13#10 + '</p>');
Value := StringReplace(Value, #13#10, ' ');
Value := StringReplace(Value, '<br><br>', #13#10);
HtmlDecode(Value);
Value2 := Value2 + #13#10 + FullTrim(Value);
HTMLDecode(Value2);
SetField(fieldComments, 'USER COMMENTS:' + Value2 + #13#10);
if (GetOption('CommentType') = 0) then
Value := TextAfter(PageText, '/comments">');
if Value <> '' then
HTMLDecode(Value);
while Pos(' ', Value) > 0 do
Value := StringReplace(Value, ' ', ' ');
while Pos(#13#10, Value) = 1 do
Delete(Value, 1, 2);
if (GetOption('CommentType') = 2) then
SetField(fieldComments, '');
// TagLine
if GetOption('GetTagline') > 0 then
Value := TextBetween(PageText, '<h5>Tagline:</h5>', '</div>');
if Pos('<a', Value) > 0 then
Value := TextBefore(Value, '<a', '');
HTMLDecode(Value);
if Value <> '' then
if StrGet(Value, 1) <> '"' then
Value := '"' + Value + '"';
case GetOption('GetTagline') of
1:
if GetField(fieldDescription) <> '' then
Value := Value + #13#10 + #13#10 + GetField(fieldDescription);
2:
if GetField(fieldComments) <> '' then
Value := Value + #13#10 + #13#10 + GetField(fieldComments);
// Trivia
if GetOption('Trivia') > 0 then
sleep(50);
Value := MovieUrl;
FullValue := ConvertToASCII(GetPage(Value+'/trivia'));
case GetOption('Trivia') of
1,2:
Value := TextBetween(FullValue, '<div class="sodatext">', '</div>');
3,4:
Value := TextBetween(FullValue, '<div class="list">', '<div id="sidebar">');
if Value <> '' then
Value := StringReplace(Value, #13#10, '');
Value := StringReplace(Value, ' ', '');
while Pos('<span class="linksoda">', Value) > 0 do
Value := StringReplace(Value, TextBetween(Value, '<span class="linksoda">', '</div>'), '');
Value := StringReplace(Value, '<span class="linksoda"></div>', '');
Value := StringReplace(Value, 'Link this trivia', '');
Value := StringReplace(Value, '<div class="sodatext">', #13#10 + '- ');
Value := StringReplace(Value, TextBetween(Value, '<script type="text/javascript">', '</script>'), '');
HTMLDecode(Value);
Value := RegExprSetReplace('\s[\d,]+\s+of\s+[\d,]+\sfound\sthis\sinterestingInteresting\?YesNo\|', Value, '', false);
Value := RegExprSetReplace('\s*Is\sthis\sinteresting\?Interesting\?YesNo\|', Value, '', false);
Value := RegExprSetReplace('Spoilers\sThe\strivia\sitems?\sbelow\smay\sgive\saway\simportant\splot\spoints\.\s*', Value, #13#10 + 'Spoilers:' + #13#10, false);
Value := RegExprSetReplace('\s*See\salsoGoofs.*', Value, '', false);
if (GetOption('Trivia') = 1) or (GetOption('Trivia') = 2) then
Value := ' ' + Value;
1,3:
Value := GetField(fieldDescription) + #13#10 + #13#10 + 'IMDB TRIVIA:' + Trim(Value)
Value := 'IMDB TRIVIA: ' + Value;
2,4:
Value := GetField(fieldComments) + #13#10 + #13#10 + 'IMDB TRIVIA:' + Trim(Value)
// Awards
if (GetOption('Awards') > 0) then
ImportAwards();
// Rating
// (Remove the "//" of the next two lines beginning with "Value" and add "//" to the following two lines beginning with Value
// if you would like to import arithmetic ratings instead of IMDB's user ratings)
// Value := ConvertToASCII(GetPage(MovieURL + '/ratings'));
// Value := TextBetween(Value, 'Arithmetic mean = ', '. ');
Value := TextBetween(PageText, '<h5>User Rating:</h5>', '</b>');
Value := TextBetween(Value, '<b>', '/');
if Value <> '' then
if (GetOption('RoundRating') = 1) then
SetField(fieldRating, IntToStr(Round(StrToFloat(Value))))
SetField(fieldRating, Value);
if GetOption('UserRatings') > 0 then
Value := TextBetween(PageText, '<a href="ratings" class="tn15more">', '</a>');
if Value <> '' then
Value := 'User Rating: ' + GetField(fieldRating) + ' out of 10 (with ' + Value + ')';
if (GetOption('UserRatings') = 1) and (Value <> '') and (CanSetField(fieldMediaType)) then
if (GetOption('UserRatings') = 2) and (Value <> '') then
SetField(fieldComments, GetField(fieldComments) + #13#10 + #13#10 + Value);
// Classification
if CanSetField(fieldCertification) then
if UserCountry = '' then
ShowMessage('Country not set for classification selection - Click "Editor" tab in the scripting window, then select your country by modifying the required line as explained in the first lines of the code')
Value := TextBetween(PageText, '<a href="/search/title?certificates=', '</div>');
Value := TextBetween(Value, UserCountry + ':', '</a>');
if Value <> '' then
SetField(fieldCertification, Value);
// MPAA rating
if (GetOption('MPAA') > 0) then
Value := FullTrim(TextBetween(PageText, '<h5><a href="/mpaa">MPAA</a>:</h5>', '</div>'));
// Value := TextAfter(Value, #13#10);
if Value <> '' then
if GetOption('MPAA') = 1 then
SetField(fieldMediaType, TextBetween(Value, 'Rated ', ' '))
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
Value, Value2: string;
if MultipleValues = 0 then
Value := TextBetween(PageText, StartTag, '</a>');
Value2 := TextAfter(Value, '">');
Value := TextBetween(PageText, StartTag, '</div>');
Value2 := TextBefore(Value, '<a class="tn15more inline"', '');
if Value2 = '' then
Value2 := Value;
if MultipleValues = 1 then
Value2 := StringReplace(Value2, ' | ', ', ');
if MultipleValues = 2 then
Value2 := StringReplace(Value2, ' | ', ' / ');
if MultipleValues = 3 then
Value2 := '';
Value2 := StringReplace(Value2, #13#10, '');
Value2 := StringReplace(Value2, ' , ', ', ');
HTMLDecode(Value2);
Result := FullTrim(Value2);
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
//Import small picture from IMDB movie main page
function ImportSmallPicture(PageText: string): Boolean;
Value: string;
Result := False;
Value := TextBetween(PageText, '<div class="photo">', '</div>');
if (Value <> '') and (Pos('"Poster Not Submitted"', Value) = 0) then
Value := TextBetween(Value, 'src="', '"');
if Value <> '' then
GetPicture(Value);
Result := True;
//Import large image from link on IMDB movie main page
function ImportLargePicture(PageText: string): Boolean;
Value: string;
Result := False;
if (Value <> '') and (Pos('"Poster Not Submitted"', Value) = 0) and (Pos('<a name="poster" href="/rg/action-box-title/primary-photo', Value) > 0) then
Value := TextBetween(Value, 'href="/rg/action-box-title/primary-photo', '"');
if Value <> '' then
Value := 'http://www.imdb.com' + Value;
Value := GetPage(Value);
Value := TextBetween(Value, 'primary-img', '</div>');
if (Value <> '') and (Pos(' src="', Value) > 0) then
Value := TextBetween(Value, ' src="', '"');
GetPicture(Value);
Result := True;
//Image not available, import "No Poster Available" icon
function ImportPictureNotAvailable(PageText: string): Boolean;
Value: string;
Result := False;
if (Value <> '') and (Pos('"Poster Not Submitted"', Value) > 0) then
if Value <> '' then
GetPicture(Value);
Result := True;
//Image from DVD Details Page
function ImportDvdDetailsPicture: Boolean;
Value, PageText: string;
Result := False;
PageText := ConvertToASCII(GetPage(MovieUrl+'/dvd'));
Value := TextBefore(PageText, '.jpg alt="', '<table class="dvd_section" cellpadding="10"><tr>');
if Value <> '' then
Value := TextBetween(Value, '<a href="', '">');
if Value <> '' then
Result := ImportFromAmazonRedirect('http://www.imdb.com' + Value);
//Image from Merchandising Links (/sales) Page
function ImportMerchandisingPicture: Boolean;
Result := False;
PageText := ConvertToASCII(GetPage(MovieUrl+'/sales'));
Value := TextBefore(PageText, '.jpg" width=', '<td class=w_rowtable_colcover><a href="');
if Value <> '' then
Value := TextBefore(Value, '"><img', '');
if Value <> '' then
function ImportFromAmazonRedirect(Url: string): Boolean;
Result := False;
PageText := ConvertToASCII(GetPage(Url));
Value := TextBetween(PageText, '<td id="prodImageCell"', '" id="prodImage"');
// Value := StringReplace(TextAfter(Value, ' src="'), '_AA240', '');
Value := StringReplace(Value, TextBetween(Value, '_AA', '_'), '');
Value := StringReplace(TextAfter(Value, ' src="'), '_AA', '');
if Value <> '' then
GetPicture(Value);
Result := True;
// ***** Gets summaries for the movie, based on the plot outline given in parameter (that contains the URL to more summaries) *****
function ImportSummary(PlotText: string): string;
Address, Value, Value2, Value3, Value4, PageText, Longest: string;
Address := TextBetween(PlotText, '<a class="tn15more inline" href="', '" ');
if (Address = '') or (GetOption('DescriptionSelection') = 0) or (GetOption('DescriptionSelection') = 3) then
Value3 := FullTrim(TextBefore(PlotText, '<a class="tn15more inline"', ''));
if Value3 = '' then
Value3 := FullTrim(PlotText);
HTMLRemoveTags(Value3);
HTMLDecode(Value3);
if (Address <> '') and (GetOption('DescriptionSelection') > 0) then
PageText := ConvertToASCII(GetPage('http://www.imdb.com' + Address));
PickListClear;
Longest := '';
//Value := TextBetween(PageText, '<p class="plotpar">', '</p>');
Value := TextBetween(PageText, '<p class="plotSummary">', '</p>');
//Value := TextBefore(Value, '<i>', '');
Value := FullTrim(StringReplace(Value, #13#10, ' '));
HTMLDecode(Value);
if Length(Value) > Length(Longest) then
Longest := Value;
PickListAdd(FullTrim(Value));
if (GetOption('BatchMode') > 0) or (GetOption('DescriptionSelection') = 2) then
Value4 := Longest
if not PickListExec('Select a description for "' + GetField(fieldOriginalTitle) + '"', Value4) then
Value4 := '';
if Value3 <> '' then
if Value4 <> '' then
Result := Value3 + #13#10 + #13#10 + Value4;
Result := Value3;
Result := Value4;
// Import awards
procedure ImportAwards;
IndexPage: TStringList;
PageText, FullValue, Block, Value, Row, Outcome, Details, AwardShow, PageText1: string;
Year, Result, Award, Category: string;
sleep(50);
Value := MovieUrl;
PageText := ConvertToASCII(GetPage(Value+'/awards'));
AwardShow := TextBetween(PageText, '<h3>', '</h3>');
if Pos('User Lists', AwardShow) > 0 then
break;
HTMLRemoveTags(AwardShow);
HTMLDecode(AwardShow);
AwardShow := FullTrim(AwardShow);
AwardShow := StringReplace(AwardShow, #13, '');
AwardShow := StringReplace(AwardShow, #10, '');
FullValue := FullValue + #32 + AwardShow + #13#10;
PageText1 := TextBetween(PageText, '<table class="awards"', '</table>');
Block := PageText1;
Row := TextBetween(Block, '<tr>', '</tr>');
Block := RemainingText;
Outcome := TextBetween(Row, '<b>', '</b>');
Category := TextBetween(Row, '<span class="award_category">', '</span>');
Award := TextBetween(Row, '<td class="award_description">', '</td>');
Details := TextBetween(Row, '<div class="award_detail_notes">', '</div>');
If Outcome <> '' then
FullValue := FullValue + #32 + Outcome + #13#10;
If Category <> '' then
FullValue := FullValue + #32 + Category;
If Award <> '' then
Award := StringReplace(Award, '<br />', #32);
HTMLRemoveTags(Award);
HTMLDecode(Award);
Award := StringReplace(Award, #13, '');
Award := StringReplace(Award, #10, '');
Award := FullTrim(Award);
Award := StringReplace(Award, ' ', '');
FullValue := FullValue + #32 + Award;
If Details <> '' then
HTMLRemoveTags(Details);
HTMLDecode(Details);
Award := StringReplace(Details, #13, '');
Award := StringReplace(Details, #10, '');
Award := FullTrim(Details);
FullValue := FullValue + #32 + Details + #13#10;
until (Row = '');
until (PageText1 = '');
// ShowInformation(FullValue);
case GetOption('Awards') of
1:
Value := GetField(fieldDescription) + #13#10 + #13#10 + 'AWARDS: ' + #13#10 + FullValue
Value := 'AWARDS: ' + FullValue;
2:
Value := GetField(fieldComments) + #13#10 + #13#10 + 'AWARDS: ' + #13#10 + FullValue
// ***** beginning of the program *****
if ShowWarning('Old version of file "Stringutils1.pas" detected: v'+IntToStr(StringUtils1_Version)+#13#10+'The script requires at least version 7.'+#13#10+'Download and install latest version now ?') = True then
UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
UpdateFile.Free;
ShowInformation('StringUtils1 has been updated. Please restart IMDB script now. Thank you.');
Exit;
ShowInformation('You can download latest version of "StringUtils1.pas" using script "update scripts" or via http://update.antp.be/amc/scripts');
Exit;
// Check for current AMC version
if CheckVersion(4,2,0) then
MovieName := '';
if GetOption('BatchMode') = 2 then
MovieName := GetField(fieldURL);
if Pos('imdb.com', MovieName) = 0 then
MovieName := '';
if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
Exit;
Sleep(500);
if MovieName <> '' then
if Pos('imdb.com', MovieName) > 0 then
AnalyzeResultsPage(MovieName)
else if RegExprSetExec('tt[0-9]+', moviename) then
AnalyzeResultsPage('http://www.imdb.com/title/' + MovieName)
MovieName := UTF8Encode(StringReplace(MovieName, '&', 'and'));
if (GetOption('BatchMode') > 0) or (GetOption('PopularSearches') = 1) then
AnalyzeResultsPage(PopularTitleSearchURL + UrlEncode(MovieName))
AnalyzeResultsPage(FullTitleSearchURL + UrlEncode(MovieName));
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2)');
lsstan
elman
Raoul_Volfoni
Hi elman,
Thanks for this update
If you have not seen this topic, it would be better to adjust some lines in the script.
In the "beginning of the program"
Change this line to
and this line
to
Thanks in advance.
Change this line
if CheckVersion(4,1,0) thenCode: Select all
if CheckVersion(4,2,0) thenCode: Select all
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.1)'); Code: Select all
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 4.2)');-
elman
