NFO Export & Custom fields?
Ant Satisfied User
Post by Ant Satisfied User »
I need export to NFO (plain text) and the "line breaks replacer" is bad idea in that case, a checkbox would fix the problem.
Other suggestion is allow to add custom fields (and their tags, of course), and yes, this is more complex to do it :-( ... but i don't like to use the "Comments" field to this purpose (and the program don't remember the resized state of this field).
Note: Sorry for this very bad english ;-)
For the linebreaks I will try to do something such as leave the field empty to no replace linebreaks ;)
For the fields, i do not know yet how to manage it, so if I do that it will not be before version 3.5 or even 4.0
For the comment field, I know that there is a problem with this resize thing, I have to arrange that :/
