Serbian language
ZoNi
Serbian language
Post by ZoNi »
when will you add Serbian language? (I sent it to you few days ago...)
AMC is really GREAT piece of software!!! :clapping:
Sure, I'll add it ;)
I am waiting for a Swedish translation actually, so I wait a little so I can add several translations at the same time.
ZoNi
Post by ZoNi »
ok...
one more: If I find any errors in my translation, should i send you new version? (i mean, how often will you add it to your program?)
you can send it when you correct it ;)
I can't say how often I update the program, it depends of the number of scripts/translations updates, and of the bugs of the programs :D
Sometimes it is important so I update quickly when the problem is fixed (e.g. when IMDB changed their site). But when it is less important I wait to have several things to update.
ZoNi
Serbian LAT
Post by ZoNi »
Serbian Latin translation updated (2009-03-25).
http://www.zoniweb.com/amc/Serbian_LAT_2009-03-25.zip
Thanks ;)
