ANT 4.2b is not anymore MyFilms 6.x compatible
catalpa
Post by catalpa »
I think 4.2b modifies the custom fields with __ and MyFilms don't like that. I hope the new ANT or MyFilms Version will fix the problem :-)
Post by soulsnake »
I think MyFilms use tags for custom fields which are used for new movie fields in AMC 4.2, so the tags of custom fields are renamed with __ before.
