debug program for pk's moviedb
pele
Post by pele »
I'm modifying pk's moviedb for my own use. I'm a beginner so i'm not always know or aware what i'm changing. Even don't know sometimes where to change things to get the results i want.
I use now with notepad but find that a bit cumbersome. I can't see live what I'm changing or what i should change.
Is there a tool / editor where i can see live what i'm changing in the *.Tpl files.
How do you guys do that?
Bianca
droopy57
Post by droopy57 »
Hi
The best way to see the changes that you make to your files *.tpl is to upload them on your server after each change.
This is how I do
pele
Post by pele »
oke thanks for your advise.
The way i do it now is using dreamweaver. I don't have to upload the files because the website is running on my NAS server.
I edit the files on my NAS directly.
Thanks,
Bianca
