impawards script
bhilam
impawards script
Post by bhilam »
First of all let me thank the developer of this great software. I started using it just few days ago and am finding it great for keeping track of movies/shows/etc. Thank you.
Also i noticed that IMPAWARDS script was not downloading the posters so i started poking around with the existing script and made some modification to get it to work.
I'm no developer but can get by with coding here and there so feel free to improve upon what i've modified
Authors=micmic, bad4u
Title=IMP Awards
Description=Movie importation script for IMP Awards
Site=http://www.impawards.com/
Language=EN
Version=2.2
Requires=3.5.0
Comments=
RequiresMovies=1
[Parameters]
program impawards;
  StringUtils1;
  BaseURL = 'http://impawards.com/search.php?search_data=';
procedure AnalyzeFirstPage(IMPAwardsURL: string);
  AFPPageText: string;
  AFPPriliminarySearchValue: string;
  AFPSecondarySearchValue: string;
  AFPSecondaryURLValue: string;
  Address: string;
  AFPPageText := GetPage(IMPAwardsURL);
  Address := 'http://www.impawards.com/';
  //ShowMessage('Page Text:' + AFPPageText);
  if Pos('sorry, but the search you performed did not return any results.', AFPPageText) > 0 then
      ShowMessage('No movie found for this search');
      Exit;
  PickTreeAdd('Search results for "' + MovieName + '" on IMP Awards :', '');
  // loop through the page for the first time if the movie is found and pick each one of them for display
  AFPPriliminarySearchValue := TextBetween(AFPPageText, '<table align = center border = 0 cols = 2 width = 90%>', '</td></tr></table></div>');
  //ShowMessage('AFP Priliminary Search Value:' + AFPPriliminarySearchValue);
    AFPSecondarySearchValue := TextBetween(AFPPriliminarySearchValue, '<tr><td>','</font>');
    //ShowMessage('AFP Secondary Search Value:' + AFPSecondarySearchValue);
    AFPSecondaryURLValue := TextBetween(AFPPriliminarySearchValue, '<tr><td><a href = ','><font size = +1>');
    //ShowMessage('AFP Secondary URL Value:' + AFPSecondaryURLValue);
    AFPPriliminarySearchValue:= RemainingText;
    HTMLRemoveTags(AFPSecondarySearchValue);
    HTMLDecode(AFPSecondarySearchValue);
    //ShowMessage('AFP Secondary Search Value Cleaned Up:' + AFPSecondarySearchValue);
    if Length(AFPSecondarySearchValue) > 0 then
      PickTreeAdd(AFPSecondarySearchValue, Address + AFPSecondaryURLValue);
  until (AFPSecondarySearchValue = '');
  if PickTreeExec(IMPAwardsURL) then
    AnalyzeSecondPage(IMPAwardsURL);
    // once user selects the movie for which poster needs to be grabbed, display list of all size posters for selection
procedure AnalyzeSecondPage(IMPAwardsURL: string);
  ASPPageText: string;
  ASPGetYear: string;
  ASPPriliminarySearchValue: string;
  ASPSecondarySearchValue: string;
  ASPSecondaryURLValue: string;
  Address: string;
  PosterCount: integer;
  result: integer;
  ASPFirstLink: string;
  PosterCount := 0; //assume no posters are found
  ASPPageText := GetPage(IMPAwardsURL);
  //ShowMessage('Page Text:' + ASPPageText);
  if Pos('sorry, but the search you performed did not return any results.', ASPPageText) > 0 then
      Exit;
  ASPGetYear := TextBetween(ASPPageText, '(<a href="alpha1.html">', '</a>)</p></td>');
  //ShowMessage('ASP Get Year: ' + ASPGetYear);
  //Address := 'http://www.impawards.com/' + ASPGetYear + '/';
  Address := TextBetween(ASPPageText, '<td><div class="fb-like" data-href="', ASPGetYear) + ASPGetYear + '/';
  //ShowMessage('Address: ' + Address);
  PickTreeAdd('Posters for "' + TextBetween(ASPPageText, '<td><p class="name white">', '(<a href="alpha1.html">') + ' (' + ASPGetYear + ') " on IMP Awards :', '');
  //ASPPriliminarySearchValue := TextBetween(ASPPageText, '<div id="left_half">','border="0" />');
  // Note: Added '/' at the end of the string as a trick to getting around searching for the text until i understand better how to program in delphi
  ASPPriliminarySearchValue := TextBetween(ASPPageText, '<td><div class="fb-like" data-href="', '" data-send="false"') + '/';
  //ShowMessage('ASP Priliminary Search Value: ' + ASPPriliminarySearchValue);
  ASPFirstLink := TextBetween(ASPPriliminarySearchValue, 'http://www.impawards.com/' + ASPGetYear + '/', '/');
  //ShowMessage('First link: ' + ASPFirstLink);
  if Length(ASPFirstLink) < 1 then
      ASPFirstLink := TextBetween(ASPPageText, '<td><p class="name white">', ' (<a href="alpha1.html">');
      PickTreeAdd(ASPFirstLink , ASPPriliminarySearchValue);
      PickTreeAdd(TextBetween(ASPPriliminarySearchValue, 'http://www.impawards.com/' + ASPGetYear + '/', '/') , Address + ASPFirstLink);
  ASPSecondarySearchValue := TextBetween(ASPPageText, '<div id="altdesigns">', '</a></div></p>');
  //ShowMessage('ASP Secondary Search Value: ' + ASPSecondarySearchValue);
  if Length(ASPSecondarySearchValue) > 0 then
        ASPSecondaryURLValue:= TextBetween(ASPSecondarySearchValue, '<a href = ', '><img ');
        //ShowMessage('ASP Secondary URL Value:' + ASPSecondaryURLValue);
        ASPSecondarySearchValue:= RemainingText;
        if Length(ASPSecondaryURLValue) > 0 then
          PickTreeAdd(ASPSecondaryURLValue, Address + ASPSecondaryURLValue);
      until ASPSecondaryURLValue = '';
//    end
//  else
//    begin
//      ShowMessage('No alternate posters found');
    AnalyzeThirdPage(IMPAwardsURL);
procedure AnalyzeThirdPage(IMPAwardsURL: string);
  ATPPageText: string;
  ATPGetYear: string;
  ATPPriliminarySearchValue: string;
  ATPSecondarySearchValue: string;
  ATPSecondaryURLValue: string;
  Address: string;
  result: integer;
  ATPFirstLink: string;
  ATPPageText := GetPage(IMPAwardsURL);
  if Pos('sorry, but the search you performed did not return any results.', ATPPageText) > 0 then
      Exit;
  ATPGetYear := TextBetween(ATPPageText, '(<a href="alpha1.html">', '</a>)</p></td>');
  //ShowMessage('ASP Get Year: ' + ATPGetYear);
  //Address := 'http://www.impawards.com/' + ATPGetYear + '/posters/';
  //Address := 'http://www.impawards.com/' + ATPGetYear + '/';
  Address := TextBetween(ATPPageText, '<td><div class="fb-like" data-href="', ATPGetYear) + ATPGetYear + '/';
  PickTreeAdd('List of all size posters for "' + TextBetween(ATPPageText, '<td><p class="name white">', '(<a href="alpha1.html">') + ' (' + ATPGetYear + ') " on IMP Awards :', '');
  ATPPriliminarySearchValue := TextBetween(ATPPageText, '<div id="left_half">','border="0" />');
  //ShowMessage('ATP Priliminary Search Value: ' + ATPPriliminarySearchValue);
  if pos('other sizes', ATPPriliminarySearchValue) > 0 then
      //ShowMessage('Multiple size poster found.');
      // handle the current page poster which is smaller size as everyone may not want to grab the biggest size poster
      ATPFirstLink := StringReplace(TextBetween(ATPPriliminarySearchValue, '<img src="posters/', '" alt ='), 'jpg', 'html');
//      ShowMessage('First page link: ' + ATPFirstLink);
//      ShowMessage('created link: ' + Address + ATPFirstLink);
      PickTreeAdd(TextBetween(ATPPriliminarySearchValue, '<img src="posters/','.jpg" alt') + '.html', Address + ATPFirstLink);
        ATPSecondarySearchValue := TextBetween(ATPPriliminarySearchValue, '<a href = ','</a>');
        //ShowMessage('ATP Secondary Search Value:' + ATPSecondarySearchValue);
        ATPSecondarySearchValue:= StringReplace(ATPSecondarySearchValue, '>', ': ');
        ATPSecondaryURLValue := TextBetween(ATPPriliminarySearchValue, '<a href = ','>');
        //ShowMessage('ATP Secondary URL Value:' + ATPSecondaryURLValue);
        ATPPriliminarySearchValue:= RemainingText;
        HTMLRemoveTags(ATPSecondarySearchValue);
        HTMLDecode(ATPSecondarySearchValue);
        if Length(ATPSecondarySearchValue) > 0 then
          PickTreeAdd(ATPSecondarySearchValue, Address + ATPSecondaryURLValue);
        //ShowMessage('ATP Secondary Search Value Cleaned Up:' + ATPSecondarySearchValue);
      until ATPSecondarySearchValue = '';
      //ShowMessage('Only one size poster found');
      ATPSecondarySearchValue := TextBetween(ATPPriliminarySearchValue, 'alt = "','"');
      ATPSecondaryURLValue := TextBetween(ATPPriliminarySearchValue, '<img src="posters/','.jpg" alt') + '.html';
    // now grab the address and call the procedure to extract poster from there
    AnalyzeMoviePage(IMPAwardsURL);
function CountSubstring(const aString, aSubstring: string): Integer;
  lPosition: Integer;
  Result := 0;
  lPosition := PosEx(aSubstring, aString);
  while lPosition <> 0 do
    Inc(Result);
    lPosition := PosEx(aSubstring, aString, lPosition + Length(aSubstring));
  PosIni, PosFin: Integer;
  dirBase: string;
  txtTemp: string;
  ImgTMP: string;
  //ShowMessage('Text:' +StringReplace(GetPage(Address), '<br>', #13#10));
  Page.Text := StringReplace(GetPage(Address), '<br>', #13#10);
  //obtenemos directorio base
  PosFin := 0;
  dirBase := Address;
  PosIni := pos('/', dirBase);
  while PosIni > 0 do
    PosFin := PosFin + PosIni;
    dirBase := Copy(dirBase, PosIni + 1, Length(DirBase));
  dirBase := Copy(Address, 1, PosFin);
//  ShowMessage('dirBase: ' + dirBase);
//  ShowMessage('Page Text: ' + Page.Text);
  //buscamos la imagen
  txtTemp := '<img src="posters/';
  PosIni := pos(txtTemp, Page.Text);
//  ShowMessage('Position: ' + IntToStr(PosIni));
  if PosIni > 0 then
      txtTemp := Copy(Page.Text, PosIni + Length(txtTemp), 100);
      PosFin := pos('"', txtTemp);
      ImgTMP := Copy(txtTemp, 1, PosFin - 1);
      GetPicture(dirBase + 'posters/' + ImgTMP);
      txtTemp := '<img SRC="posters/';
      if PosIni > 0 then
          //ShowMessage('Getting: ' + dirBase + 'posters/' + ImgTMP);
  //DisplayResults;
// bmicmic: Bucle Principal
  if CheckVersion(3,5,0) then
      Input('Import of IMP Awards', 'Enter the title of the movie:', MovieName);
      //ShowMessage('URL: ' + BaseURL + UrlEncode(MovieName));
      AnalyzeFirstPage(BaseURL + UrlEncode(MovieName));
    ShowMessage('This scripts requires a newer version of Ant Movie Catalog (at least the version 3.5.0)');
While uploading it to the server, I also changed the version to 2.3 and added your nickname to the authors list.
bhilam
Post by bhilam »
Updated IMPAwards Script since the current one broke due to changes on their site.
Title=IMP Awards
Language=EN
Version=2.4
Requires=3.5.0
Comments=
RequiresMovies=1
[Parameters]
program impawards;
  StringUtils1;
  tmpMovieName: string; // used to replace spaces with period
  Address: string;
  //ShowMessage('1st Page Text:' + AFPPageText);
      Exit;
  //AFPPriliminarySearchValue := TextBetween(AFPPageText, '<table align = center border = 0 cols = 2 width = 90%>', '</td></tr></table></div>');
  AFPPriliminarySearchValue := TextBetween(AFPPageText, '<div class = row align = center>','<div class ="col-sm-4">');
    //AFPSecondarySearchValue := TextBetween(AFPPriliminarySearchValue, '<tr><td>','</font>');
    AFPSecondarySearchValue := TextBetween(AFPPriliminarySearchValue, '><h2>','</h2><a href');
    //AFPSecondaryURLValue := TextBetween(AFPPriliminarySearchValue, '<tr><td><a href = ','><font size = +1>');
    AFPSecondaryURLValue := TextBetween(AFPPriliminarySearchValue, '<div class = col-sm-12><a href = ','><h2>');
  ASPGetYear: string;
  Address: string;
  result: integer;
  //ShowMessage('2nd Page Text:' + ASPPageText);
      Exit;
  //ASPGetYear := TextBetween(ASPPageText, '(<a href="alpha1.html">', '</a>)</p></td>');
  ASPGetYear := TextBetween(ASPPageText, '(<a href="alpha1.html">', '</a>)</h4></p>');
  Address := TextBetween(ASPPageText, '<div class="fb-comments" data-href="', ASPGetYear) + ASPGetYear + '/';
  //PickTreeAdd('Posters for "' + TextBetween(ASPPageText, '<td><p class="name white">', '(<a href="alpha1.html">') + ' (' + ASPGetYear + ') " on IMP Awards :', '');
  PickTreeAdd('Posters for "' + TextBetween(ASPPageText, '<p><h4 align = center>', '(<a href="alpha1.html">') + ' (' + ASPGetYear + ') " on IMP Awards :', '');
  ASPPriliminarySearchValue := TextBetween(ASPPageText, '<div class="fb-comments" data-href="', '" data-width="600" data-num-posts=') + '/';
  //ShowMessage('3rd Page Text:' + ASPPageText);
  ASPSecondarySearchValue := TextBetween(ASPPageText, '<div id="altdesigns">', '></a></div>');
//    end
//  else
//    begin
  ATPGetYear: string;
  ATPPrePriliminarySearchValue: string;
  Address: string;
  result: integer;
  //ShowMessage('4th Page Text:' + ATPPageText);
      Exit;
  ATPGetYear := TextBetween(ATPPageText, '(<a href="alpha1.html">', '</a>)</h4></p>');
  Address := TextBetween(ATPPageText, '<div class="fb-comments" data-href="', ATPGetYear) + ATPGetYear + '/';
  PickTreeAdd('List of all size posters for "' + TextBetween(ATPPageText, '<p><h4 align = center>', '(<a href="alpha1.html">') + ' (' + ATPGetYear + ') " on IMP Awards :', '');
  //ShowMessage('5th Page Text:' + ATPPageText);
  ATPPrePriliminarySearchValue := TextBetween(ATPPageText, '<p class="small" align = center>',' border="0" />');
  //ShowMessage('ATP Pre-Priliminary Search Value: ' + ATPPrePriliminarySearchValue);
  ATPPriliminarySearchValue := TextBetween(ATPPageText, '<img src="','" class="img-responsive" alt = ');
  if pos('other sizes', ATPPrePriliminarySearchValue) > 0 then
      ATPFirstLink := StringReplace(TextBetween(ATPPrePriliminarySearchValue, '<img src="posters/', '" class="img-responsive" alt ='), 'jpg', 'html');
      //ShowMessage('First page link: ' + ATPFirstLink);
      //ShowMessage('created link: ' + Address + ATPFirstLink);
      //ShowMessage('ATPPrePriliminarySearchValue: ' + ATPPrePriliminarySearchValue);
      PickTreeAdd(TextBetween(ATPPrePriliminarySearchValue, '<img src="posters/','.jpg" class') + '.html', Address + ATPFirstLink);
        ATPSecondarySearchValue := TextBetween(ATPPrePriliminarySearchValue, '<a href = ','</a>');
        ATPSecondaryURLValue := TextBetween(ATPPrePriliminarySearchValue, '<a href = ','>');
        ATPPrePriliminarySearchValue:= RemainingText;
      //ShowMessage('ATP Pre-Priliminary Search Value:' + ATPPrePriliminarySearchValue);
      ATPSecondarySearchValue := TextBetween(ATPPrePriliminarySearchValue, 'alt = "','"');
      ATPSecondaryURLValue := TextBetween(ATPPrePriliminarySearchValue, '<img src="posters/','.jpg" class') + '.html';
      //ShowMessage('Address: ' + Address + ATPSecondaryURLValue);
  lPosition: Integer;
  Result := 0;
    Inc(Result);
  dirBase: string;
  txtTemp: string;
  ImgTMP: string;
  PosFin := 0;
  dirBase := Address;
  while PosIni > 0 do
  //ShowMessage('Page Text: ' + Page.Text);
  if PosIni > 0 then
      if PosIni > 0 then
  //DisplayResults;
      //replace spaces with period to accomodate IMPAwards search string changes
      tmpMovieName := StringReplace(MovieName, ' ', '.');
      MovieName :=  tmpMovieName;
bhilam
Re: impawards script
Post by bhilam »
Authors=micmic, bad4u, bhilam
Title=IMP Awards
Language=EN
Version=2.5
Requires=3.5.0
Comments=
RequiresMovies=1
[Parameters]
program impawards;
  StringUtils1;
  Address: string;
      Exit;
  AFPPriliminarySearchValue := TextBetween(AFPPageText, '<div class = row align = center><div class = col-sm-12>','<div class ="col-sm-4">');
    AFPSecondarySearchValue := TextBetween(AFPPriliminarySearchValue, '<h3>','</h3>');
    AFPSecondaryURLValue := TextBetween(AFPPriliminarySearchValue, '<a href = ','><img src = ');
//ShowMessage('New Address: ' + Address + AFPSecondaryURLValue);
  ASPGetYear: string;
  Address: string;
  result: integer;
      Exit;
      ASPFirstLink := TextBetween(ASPPageText, '<p><h4 align = center>', '(<a href="alpha1.html">');
//ShowMessage('Zero First link: ' + ASPFirstLink);
//ShowMessage('Non-Zero First link: ' + ASPFirstLink);
//    end
//  else
//    begin
  ATPGetYear: string;
  Address: string;
  result: integer;
      Exit;
  lPosition: Integer;
  Result := 0;
    Inc(Result);
  dirBase: string;
  txtTemp: string;
  ImgTMP: string;
  PosFin := 0;
  dirBase := Address;
  while PosIni > 0 do
//ShowMessage('dirBase: ' + dirBase);
  if PosIni > 0 then
//ShowMessage('Position: ' + IntToStr(PosIni));
      if PosIni > 0 then
  //DisplayResults;
