How to delete Leading or Trailing Spaces?
Ray
Post by Ray »
Hey There,
I love this Tool! But I'm having one issue, I can't seem to find a way to remove Leading or Trailing Spaces without deleting any text from folders/files if anyone knows how please let me know!
Example
_____________________________
Hello .txt
Hello 2.txt
To:
Hello.txt
Hello 2.txt
Ray :)
Using the "regular expression" action you could do that easily.
Expression = (.+)\s\.([^\.]+)
New Name = $1.$2
The expression searches for :
- any character (1 or more) -> the base name
- at least a space
- a dot
- any character (1 or more) except a dot -> the extension
New name is generated with the two parts between parenthesis (base name & extension)
Check using the preview fonction before renaming, to be sure it works in all cases ;)
Ray
Post by Ray »
Hey antp,
Thanks for the reply I really appreciate it. That expression worked like a charm and for the explanation as well. I wish I understood expressions better, it would help me out a lot.
Though as side note, it would be awesome to see this as a preset feature in the possible future for new people like me.
Thanks,
Ray :wink:
Yes that's something I should add, some presets-expressions for ordinary tasks. But as many things on my to-do list... they tend to stay on the to-do list :lol:
