Adding more than 2 divx on a DVD
itajackass
Post by itajackass »
hi, i stored my divx in several dvd. some dvd contains more than 2 divx... so if select to allow duplicate numbers in catalog is ok for 2 divx on a single DVD, but for 3 divx or more in a single DVD is a problem cause i can't create more than 2 equal numbers for the collection. how can i do? thanks
:??: There is no problem for creating more than two identical numbers
But was I was doing for handling that is giving each movie its own number, and putting the number of the first movie of the DVD to the media label field of each movie of the DVD, as a DVD number then.
itajackass
mh not...i cannot. :( see picture:
http://imageshack.com/a/img811/2595/r0p2.jpg
:??: just click "ok"
Once you already have duplicates it does not ask you what to do: it assumes you are ok having duplicates.
Maybe the "accept" option should be checked by default then, to be more clear.
