I get this message sometimes when I try to close the program:
Access violation at address 00BBB0E4. Write of address FFFFFFFB5
Then you have to close the program from the task manager...
a bug...?
mikskov
i'll try to describe it...
Ok, I'll make an attempt to descibe how I experienced it.
When you use the shortkey [shift + F9] to get data from files there is a small amount of time the computer works (since I've collected data from CD's). Now, if you switch program during this time, for example switch to MS Outlook window and return to Ant Movie Catalog the pop-up window where you select the file to get the data from is diappeared. The only way to get this window up again is to select the "get data from files" from the menu. (The shortcut key now does not work.) Finally, try to close the program... you should experience this bug then.
Hope this helps although the explonation perhaps was not the best...
a suggestion...
try to insert an cd in you cd-rom, as it spins up press shift+f9 this should provide the time i'm speaking about... (try to go to another window and after a while go back again) hope this helps
