[New] Nature Template by sajrockz
Is it Good or Bad? (I would like to improve my works)
Excellent
6
67%
Good
3
33%
Not Bad
0
No votes
Bad
0
No votes
Total votes: 9
sajanbs4@gmail.com
Post by sajanbs4@gmail.com »
This is my second theme: Nature
Download 4shared
Direct Download
Request you all for your feedback.. :)
admas
Post by admas »
I'm sorry, but I can not download and vote. Share on another server.
Raoul_Volfoni
Post by Raoul_Volfoni »
admas wrote:I'm sorry, but I can not download and vote. Share on another server.
Answer here
Post by soulsnake »
Hi sajanbs4,
Thank you, the template is very good.
I just upload it here for people who can not download it with your link :
http://mickaelvanneufville.online.fr/AM ... Nature.rar
sajanbs4@gmail.com
Thank u soulsnake :)
i have added the link to the main topic.. :grinking:
sajanbs4@gmail.com
I have added direct download link posted by Soulsnake :)
admas
Post by admas »
Thanks :grinking:
MMM
Re: [New] Nature Template by sajrockz
Post by MMM »
Hello.
I use AMC for a long time and I just love it, thank you very much. I also use this template, it's the one I prefer.
I just would like to know how can I change from 5 actor photos to 10 actor photos in 2 rows.
I´ve tryed several changes on the script, but I can not make it to work.
Can anyone help me, please?
Thank you very much.
What did you try?
I see in the code this block corresponding to the extra info of actors:
			<tr>
			$$ITEM_EXTRA_BEGIN(Actors,,1,5)
			<td><img src="$$ITEM_EXTRA_PICFILENAME" alt="actors" width="105" height="155" border="2"></td>
			$$ITEM_EXTRA_END
			</tr>
			<tr>
			<td class="actors" width= "105"><a href="http://www.imdb.com/name/$$ITEM_EXTRA_URL"><b>$$ITEM_EXTRA_TITLE</b></a><br>$$ITEM_EXTRA_DESCRIPTION</td>
			$$ITEM_EXTRA_END
			</tr>
have you tried to simply duplicate it, and put 6,10 instead of 1,5 in the two "begin" lines of the duplicated block?
MMM
Post by MMM »
Thank you for the sugestion. I only tryed changing 1,5 by 1,10, but I got one single line with 10 photos, so it was very long and added a scroll on the bottom.
I'll try your way and update this post.
MMM
Post by MMM »
IT WORKED !! :clapping: :clapping:
Thank you again and keep up the good work
Best regards
MMM
Post by MMM »
Hello!
I have another question about this template. :??:
What do I have to do so the country flags show in the ''Movie Info''
I only get an empty square after the name of the country. The flags folder (with 333 flags or combinations) is inside ''Nature'' folder.
Thank you very much ;)
MMM
Valmiki
Post by Valmiki »
Hello,
I see that there was no reply to the last question but since I have an extra one I ask.
I have the same problem with the flags.
In addition I tried to modify the html file as described above and change the actor's number to 10 but what I see is 2 rows with the same 5 actors on each row. What am I doing wrong?
Valmiki
Post by Valmiki »
Ok. I found out my problem. The modification above is perfect. But because I already added the actors in the process of the change somehow the movie got stuck so I had to remove the actors from the Extra fields and reimport. Problem solved.
For the flags I also found the problem. Unfortunately the names got changed at a certain point. So for example USA has to be renamed with United States. I just did this test and it worked. For everything else, just write whatever is written before the flag. I am changing what I am finding in my database and it all works. To see the changes just made, it seems enough to click on another movie and go back to the one that you just changed the flag for and you already see the modification.
MMM
Post by MMM »
Thank you for the solution about the flags, it's very simple but yet we do not use to think for the easiest way.
Also, we can duplicate a flag with the variant name, so it covers more options.
:clapping: :grinking:
