Elseif
wbshrk
Elseif
Post by wbshrk »
How does Else if work in the scripts?
what do you mean?
You can write:
if something then
  some code
else if somethingelse then
  some code
and begin/end is optional if there is only one code instruction in the block
wbshrk
Post by wbshrk »
I have tried that at the script error out at the first else if. See code below. if I just use plan if it works fine.
  if Value <> '' then
      if RegExprSetExec('drama',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Drama');
      else if RegExprSetExec('comedy',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Comedy') ;
      else if RegExprSetExec('romance',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Romance') ;
      else if RegExprSetExec('animation',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Animation');
      else if RegExprSetExec('action.*adventure',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Action/Adventure') ;
      else if RegExprSetExec('anime',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Anime') ;
      else if RegExprSetExec('fantasy',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Fantasy');
      else if RegExprSetExec('science.*fiction',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Sci-Fi');
      else if RegExprSetExec('comic.*book',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Comic book');
      else if RegExprSetExec('family',AnsiLowerCase(Value)) = True then
      SetField(fieldCategory, 'Family');
Post by soulsnake »
Do not put ; before else :
  if Value <> '' then
It is indeed one of the few particularity of the Pascal/Delphi, no ";" in front of else (and optional in front of "end" if I remember well)
Really interesting.
Use of if... then... else... was a little confusing but now... it's all clear!
Tnx.
:grinking:
