This afternoon was working, but right now, when I try to launch it, a warning message appears: UNIT IS NOT FOUND IN LINE 4.
My script is 3.81 version, and I downloaded it again to be sure that the failure wasn't mine.
Thanks for all!
IMDB script doesn't work
you need the file StringUtils1.pas in your scripts folder. Maybe you accidentally deleted that one. You can download again from http://update.antp.be/amc/scripts/
Raoul_Volfoni
The IMDB script needs the "StringUtils1.pas" file to work.mcmanaman2000 wrote:This afternoon was working, but right now, when I try to launch it, a warning message appears: UNIT IS NOT FOUND IN LINE 4.
For some reason, you apparently don't have this file anymore.
You can find this file here and you have just to put it in the scripts directory of AMC.
Maybe a little ...mcmanaman2000 wrote:... to be sure that the failure wasn't mine.
[edit]
Grilled ...
Hi Bad4u ...
mcmanaman2000
