All Movie Guide script doesn't work
kalimagdora
Post by kalimagdora »
5 days ago something went wrong, with All Movie Guide script.
This is my message: HTTP/1.1 503 Service Unavailable
Please help !!!!! :)
thx
kalimagdora
It works by everyone else?
Post by soulsnake »
Sorry but the website allrovi.com used to search a movie seem to be unavailable.
The script should be modified to use the search results of allmovie.com if the website allrovi.com is dead definitly.
kalimagdora
I hope for a competent repair the script. I'll wait patiently.
THX for your response
Snup
Post by Snup »
Hello,
I have the same problem as Kalimagdora. Please if is it possible, please repair the script when you have time.
Ty very much.
kalimagdora
I really miss it :(
Lemaireus
All Movie Guide Script Update Request
Post by Lemaireus »
It's been a long time since update requests were posted, still no sign of an update :( Would someone who can do this please help?
kalimagdora
The original script was made by Sascha Biesgen
Lemaireus
Post by Lemaireus »
The authors mentioned in the AMG script information are Hubert Kosior, KaraGarga, Chetan Rao, and Donna Huffman. May be one of them can help if they are still active in the AMC community.
Raoul_Volfoni
Update All Movie Guide (pic) V0.7.0
Post by Raoul_Volfoni »
Hi
I heard the distress signal and I've worked for you guys.
I spent time on this script ... but I already handles a lot of scripts, so I don't have much time to spend on a new script to fix.
If there are further corrections to do, you'll have to be patient.
The All Movie Guide (pic) script in 0.7.0 version is available on antp's server.
You can find this update here : http://update.antp.be/amc/scripts/
Or You can use the [UPDATE_SCRIPTS] script to ... update your scripts !!
Changelog :
- [Fix] Nearly all the script !! :p
- [Mod] To avoid, search results problem, the "MaxResults" option is set by default to 5000
- [New] Adding of a "Picture" option with 2 choices :
  • 0 -> Big (Default setting)
    1 -> Small
(You can now choose if you want to get a small or big picture. The setting default is the big picture)
kalimagdora
Thank you very much, it works perfectly
Lemaireus
Post by Lemaireus »
Raoul, thank you very much: the script is up and running once again! However, there is one consistent problem: very often I get the message "Sorry, there are too many possible matches, please adjust your search and retry". I hope fixing that doesn't consume much of your time.
Thank you once again for your time, your effort, and your expertise.
Raoul_Volfoni
Lemaireus wrote:However, there is one consistent problem: very often I get the message "Sorry, there are too many possible matches, please adjust your search and retry". I hope fixing that doesn't consume much of your time.
Hi Lemaireus,
As I mentioned in my previous message, I increased the value of MaxResults option to avoid the problem you describe.
Check that the MaxResults option is set to at least 5000 (usually the default setting).
If it still doesn't work, try to set the option at 8000.
If it still doesn't work, give me some movie titles where you have this problem.
Re: Update All Movie Guide (pic) V0.7.0
Raoul_Volfoni wrote: The All Movie Guide (pic) script in 0.7.0 version is available here :
Shall I already put it on the server or do you want to wait more testing?
Raoul_Volfoni
antp wrote:Shall I already put it on the server or do you want to wait more testing?
Salut Antoine,
Maybe waiting a little. At least, until Lemaireus's answer.
Lemaireus
Post by Lemaireus »
Raoul, you're right, of course. I suppose the problem was that the default selection of maximum results is set to 100 in the script, and I hadn't noticed that. I changed that to 5000 and the error message has disappeared :)
Everything working perfectly for me with this script, thanks again Raoul.
Lemaireus
Issue with AMG script v0.7.0
Post by Lemaireus »
Raoul, I noticed an issue with the AMG script v0.7.0: there is a problem in importing the "synopsis" ('Overview' tab on AMG website) as well as the "review" ('Review' tab on AMG) fields.
In the "synopsis" field the script imports only the first paragraph and, in the "review" field only the first paragraph or the first 5-6 lines. This is the case with all the long synopses (tested with the plot description for "As Good As It Gets") and long reviews (tested with the titles "Zodiac," "Zombieland," and "American Gangster").
Hoping that it wouldn't take you long to fix these errors. Thanks!
Raoul_Volfoni
Update All Movie Guide (pic) V0.7.1
I just tested the script on a few films. So there may be other errors such as these ... You are beta testers ... ;)
Hope it works better like this.
The All Movie Guide (pic) script in 0.7.1 version is available on antp's server.
Changelog :
- [Fix] Synopsis (take all paragraphs)
- [Fix] AMG Review (take all paragraphs)
I use a fonction who appears in the version 7 of the Stringutils1.pas file. I have program the script to detect if you have the correct version or not. If it's not the case, the script will propose to you to download the last version. But you can do it manually.
Lemaireus
Post by Lemaireus »
Well, Raoul, that's a pretty good beta: just one error ;)
Thanks for the update: everything is working perfectly thus far for me in the updated AMG script.
I tried deleting my thread on this issue < viewtopic.php?t=5662 > to avoid duplication, but wasn't able to. Perhaps Antoine can remove that thread. In any case, I have deleted my post with the link to v0.7.0.
Beta testing report for AMG script v0.7.1: ready to be included in updated scripts :)
ok, I'll already upload it to the server :)
