Last update: 2003-03-23 - Problem remain
I have updated to the last version - Last update: 2003-03-23 -
And the problem seems to remain... no Large Pic...
I have the same problem with IMDB.... Sometimes works, in 40 movies inserted olly 3 come with large picture, a little strange (becouse the large picture is avaiable in amazon.com)
it is because the link between IMDB and Amazon is not easy to do.
When you surf on the page you see easily which item is the right one, but in the program it is not so easy to do :p
