(script) Multiple selection
J
Post by J »
hi,
The given actor sorting in IMDB isn´t helpfull sometimes, so I´d like to list all movie actors and let choose some of them for picture import.
Is there a way to use picktree or similar function with a multiple selection? Or any other idea to do this?
Post by soulsnake »
Hi J,
There is not picktree or similar function with multiple selection.
Maybe I could add this if it is really usefull.
But you can list all movie actors and ask 5 times for actor 1, 2, 3, 4, and 5.
Each time user select an actor, you remove this actor from the list and you ask for the next actor with the new list. This way user can choose actors order.
J
Post by J »
thanks, but I guess not as long as there is no other need for this.
That´s only an issue for a couple of movies where main actors are not on top of the list but sorted elsewhere.
Perhaps I´ll integrate an optional single actor import with a name input for this special cases.
thanks
J.
