Problema al buscar peliculas
lik
Post by lik »
hola, cambiando el script de filmaffinity por este nuevo me busca perfectamente, pero me ocurre un problema. Cuando le das a f6, sale la lista de script, si pulso en cualquiera me deja introducir el texto a buscar, pero en este en concreto, el de filmaffinity, no me deja buscar, y automáticamente me saca una búsqueda anterior que hice de "EL legado de Bourne". Da igual que cancele, que acepte, que guarde los datos, he probado a cambiar todo tipo de opciones, pero siempre me busca solo esa película y no me deja buscar otra. A ver si alguien me puede echar una mano.
También he desinstalado y vuelto a instalar y nada, me ocurre lo mismo
Gracias
I do not understand the translation from Google, so I can't help, sorry :/
chalket
Post by chalket »
Here is a very rough, but hopefully understandable, translation:
Hi, changing the script for this new filmaffinity worked for me perfectly, but happens to me a problem. When you hit f6, script out the list, if I click on what I want it let me enter the search string, but in this particular, that of filmaffinity will not let me look, and it automatically shows a previous search I did for "The Bourne Legacy ". Whether you cancel, to accept, to save the data, I tried to change all kinds of options, but it always just looks for that movie and not let me find another. Let's see if someone can lend a hand.
I have also uninstalled and reinstalled and nothing, the same thing happens to me
It is already a little better, thanks ;)
Maybe it is the options on the right of the scripts list: there is a "DontAsk" option that can be set to 1 to skip the title ask (double-click on it to change it).
lik
Post by lik »
i have that option with 0. I cant write text when i press f6. The script directly search. I have unnistalled and clear all folders, but i have same problem. only with filmaffinity.es. I only use that script.
Do you have the version 2.68 of the script?
As one of the first things the script does is asking the title if the option is set to 0 so I do not see what would prevent it from doing it :??:
lik
Post by lik »
i have the script from this post in first page. I have the option set in 0. im going to copy and paste first part of the script so tell me what is the error please
thanks, sorry for my english.
Authors=aviloria (aviloria@yahoo.com) modded by: rodpedja (rodpedja@gmail.com), kreti (bisoft@hotmail.com), MrK, gilistico, juliojs
Title=FilmAffinity (ES)
Language=ES
Version=2.65
Requires=3.5.0
Comments=Updated to 2013/04/16 version of the web-page. Added an option to choose Actor list format (ActorsInALine).
RequiresMovies=1
[Parameters]
program FilmAffinity;
BaseURL = 'http://www.filmaffinity.com';
MovieURL: string;
Result := -1;
Result := i;
ini, fin: Integer;
Result := '';
ini := Pos(StartTag, S);
if ini <> 0 then
fin := Pos(EndTag, S);
n, len, tag: Integer;
c, p: char;
HTMLDecode(S);
len := Length(S);
tag := 0;
p := ' ';
Result := '';
for n := 1 to len do
c := Copy(S,n,1);
// Eliminamos los tabuladores
if c = #9 then c := ' ';
if tag = 0 then
if c <> '<' then
Result := Result + c;
p := c;
else tag := 1;
Count: Integer;
Count := 0;
LineNr := FindLine('</strong> resultados.</div>', Page, 0);
if LineNr <> -1 then
Count := StrToInt(TextBetween(Line, '<div style="text-align:right;"><strong>', '</strong> resultados.</div>'), 0);
if Count = 0 then
LineNr := 0;
while true do
LineNr := FindLine('<div class="mc-title"><a href="', Page, LineNr + 1);
if LineNr = -1 then
LineNr := FindLine('<b>siguientes >></b>', Page, 0);
if LineNr = -1 then
break;
Page.Text := GetPage(TextBetween(Line, '<a href="', '">'));
LineNr := 0;
continue;
MovieAddress := TextBetween(Line, '<div class="mc-title"><a href="', '.html">') + '.html';
MovieTitle := DeleteTags(TextBetween(Line, '.html">', '<img src="'));
PickTreeAdd(MovieTitle, BaseURL + MovieAddress);
if ((Count = 1) and (GetOption('DontAsk') = 1)) or PickTreeExec(Address) then
AnalyzeMoviePage(Address);
That looks like an old script anyway, you should update it. It is version 2.65 as indicated in its header, current one is 2.68.
Run the script "update scripts" to get the latest one.
You can also get it manually from http://update.antp.be/amc/scripts/
lik
Post by lik »
Oh Thanks man!!!!!
i had updated this script manually, and didnt work.
Auto update worked ok.
Alot of thanks
theunreal
Post by theunreal »
Thank you!!!!! now it works for me too :)
Just auto update.
