Regular expression to import movies title
Usually my movies have a file name such this:
"Title (Author) Year.ext"
Would you suggest me a regular expression to delete "(Author)" while importing into AMC?
Is it possible to import such movie title into Translated Title instead of Original Title?
Many Thanks
Post by soulsnake »
I give you my generic filter to extract a movie title from movie filename.
Maybe I will update it as default in next update of AMC 4.2 beta.
Download the file bellow that contains filter and import it from window to filter filename.
http://mickaelvanneufville.online.fr/AM ... lename.txt
This regular expression will remove "(Author)":
::>\([-_ a-zA-Z0-9éëèàù,.]*\) # Remove content in brakets=
You can do this from "File > Import > Media files" and click on title column in preview list to set translated title instead of original title field
@soulsnake
Thanks for your quick answer but regular expression doesn't look to be useful and file name/movie title remains the same as before:
Convoy - Trincea d'Asfalto (Sam Peckinpah) 1978.avi
I obtain:
Convoy Trincea d'Asfalto Sam Peckinpah
while I wish:
Useful suggestions to use import.... should it be possible to obtain the same result using drag & drop??
Post by soulsnake »
I obtain:
while I wish:
I test your example with the filter I give you and I have the good result:
Do you import the filter or just add the regular explession in your filter ?
I modify the filter to support all charateres, it will work even if you have special characteres en brackets:
::>\(.*\) # Remove content in brakets=
Yes but you can not import title directly in translated title.
I will add this option in a future version (4.2.1).
After importing filter-file you gave me now it's OK!
(i wrote the filter and tried to import with drag & drop... :badidea:)
thanks! :grinking:
criza
Post by criza »
These filter rules are great, but when I import scene releases the group name won't be stripped. Here's an example:
A.Serious.Man.2009.LIMITED.DVDRip.XviD-ESPiSE-1
is
A Serious Man ESPi SE 1
(Please note I added the -1 (for CD1) at the end myself, tho it would be great if this could be stripped, too.)
or:
There.Will.Be.Blood.CD1.DVDRip.XviD-DiAMOND
is
There Will Be Blood Di AMOND
Any solution with what rule I could fix this? Thank you.
PS I thought about stripping the whole "XviD-*" or "X264-*" if it's possible to add wildcards. Surely easier than adding all group names to the filter.
Post by soulsnake »
I improve the filter to remove all content after commun values :
::> bluray.*=
::> hddvd.*=
::> dvd.*=
::> bdrip.*=
::> brrip.*=
::> webrip.*=
::> divx.*=
::> xvid.*=
::> x264.*=
::> h264.*=
You can download it here :
http://mickaelvanneufville.online.fr/AM ... ename2.txt
criza
Post by criza »
Hi & Thanks!
I found a couple more cases where the file name hasn't been stripped correctly by your filter, please see the link below, otherwise it works perfectly.
http://pastebin.com/MDcmmYW2
I'd (and others certainly too) appreciate it a lot if you could update the filter rules once again.
Post by soulsnake »
You can download the new filter here :
http://mickaelvanneufville.online.fr/AM ... ename3.txt
