script for verify the File Path?
otreux
Post by otreux »
There is a way for verity if all the File Path are correct?
There are "FileExists" and "DirectoryExists" function, at least in version 4.2 beta (not sure since when they exist).
otreux
Post by otreux »
I use the 4.2 beta, where I can find those command?
Post by soulsnake »
All the functions for scripting are described in AMC Help (F1).
Here the script to check and list movies whose file path does not exist :
program CheckFilePath;
  Path: string;
  List: TStringList;
  if GetIteration = 0 then
    List := TStringList.Create;
  Path := GetField(fieldFilePath);
  if not FileExists(Path) and not DirectoryExists(Path) then
    List.Add('  - ' + GetField(fieldFormattedTitle) + ' : ' + Path)
  if GetIteration = GetIterationCount-1 then
    ShowMemo('List of movies whose file path does not exist:' + #10 + List.Text);
    List.Free;
otreux
Post by otreux »
thank you, very kind as always :)
