Problem of GetPage() in the Script
Heartos
Post by Heartos »
While I made the Script for http://films.hitel.net, I found a problem of GetPage().
In the Webpage &lt was used. When GetPage() meets &lt in the taget page, all the words next to &lt are lost.
This result was confirmed by using ShowMessage().
How can I solve this problem?
Heartos
Modify..
Post by Heartos »
Abolve, &lt means &lt
If I remember well, it is a server-side bug that puts a byte at zero (value = 0) after this character. The functions that I use to download the file seems to cut the text when they found a 0 (which is used in C and Windows API functions as end-of-string symbol).
Heartos
Post by Heartos »
Thanks for your speedly answer.
