Hi, I have a little question. Have the AMC and I love it but I can not find out how to edit multiple movies (need only media label for multiple edit). Is there a way how to unlock it?
Thank you and sorry if it is somewhere, could not find it
Multiple edit
This can be done via scripting.
There is a script that helps you with that, if you go to Tools->Scripting (or Shift+F6) there should be one named "update fields" or something like that.
Be sure to have selected the movies to modify, and that the option "movies to include" in the scripts window is set to "selected movies".
