Use Renamer via Batch file in the "same" folder
diamondialis
Post by diamondialis »
Hey there...
I got a little problem over here.
I want to create a Batch-File "rename-files.bat" that calls the Renamer-Batch-Script "rename-files.arb".
Both files are in the same folder, but the folder variables, so i want the script to use the folder the Scipt is actually in...
But how do I realise that?
Imagine following:
I got pictures in a folder "C:\Pics\13.05 Mallorca"
my Batch-File: "C:\Pics\13.05 Mallorca\rename-files.bat"
my Renamer-Script: "C:\Pics\13.05 Mallorca\rename-files.arb"
Content of the Batch-File:
@echo off
Renamer.exe -b rename-files.arb -af *.* -g -x
Content of the Renamer-Script:
<?xml version="1.0" encoding="UTF-8"?>
<AntRenamer Version="2.10.0" Date="19.08.2013">
 <Batch>
  <Enum Mask="%folder1% [%num%]%ext%" Start="1" Digits="4" Incr="1" Restart="1"/>
  <DateTime Mask="f [yy.mm.dd - hh.nn]e" AddSuffix="0" WhichDate="0"/>
 </Batch>
</AntRenamer>
My aim is, that no matter, where i put those two files to, it still works.. with "relative paths" :)
Its actually not working... just nothing happens...
Hope someone can help me ;)
Thanks!
You could try to add %cd%\ in front of the filename and mask.
But it is strange, I would expect that the current folder would be used...
