I have a strange issue. Just installed AntViewer 1.8.1 package (+ included AMC). AMC opens correctly and I was able to enter/save info for 20 movies... but...
in AntViewer when I click on the "Edit" button, it does not open AMC, but rather another instance of the AntViewer program. ?
I have used older versions of both and normally clicking the "Edit" button opened AMC/my saved movie catalog in order to edit.
(NB, I am not very tech-savvy)
Viewer "edit" does not open AMC
miches
Possibly there is a problem in file associations.
I guess that the "Edit" of the viewer simply launches the .amc file?
You can repair associations from AMC in the options, though that might now work in Vista/7/8 if UAC is enabled (I haven't checked that actually).
You could try to force reassociating the .amc files to AMC by doing right click -> open with, on a .amc file.
miches
