how to get the folder size using ant script
jete2011
Post by jete2011 »
i copied a folder from src to destination.but i need to verify whether the size
of the folder from both source and destination are equal
Post by soulsnake »
Hi jete2011,
There is no native fonction to do this but you can use the function GetFolderSize below to do what you need.
Just copy it in your script as it is done in example below.
program ShowFolderSize;
  function GetFolderSize(path: string): double;
    s: string;
    lines: TStringList;
    values: TStringListEx;
    i: integer;
    result := 0;
    path := IncludeTrailingPathDelimiter(path);
    lines := TStringList.Create;
    values := TStringListEx.Create;
    values.Delimiter := #9;
    if DirectoryExists(path) then
      // List current folder
      s := ListDirectory(path, '*');
      // Extract lines
      lines.Text := s;
      // For all lines
      for i := 0 to lines.Count-1 do
        // Extract values of line (name, size, datetime, "D" if directory)
        values.DelimitedCSVText := lines.GetString(i);
        while values.Count < 4 do
          values.Add('');
        if (values.GetString(0) <> '') and
           (values.GetString(0) <> '.') and
           (values.GetString(0) <> '..') then
          // If it is a folder, we compute the size of this folder recursively
          if values.GetString(3) = 'D' then
            result := result + GetFolderSize(path + values.GetString(0))
          // Else we add the filesize to result
            // We use function GetFileSize to get good filesize because the size returned
            // by function ListDirectory is only good for small files < 2 147 483 648 bytes
            if FileExists(path + values.GetString(0)) then
              result := result + GetFileSize(path + values.GetString(0))
              result := result + StrToFloat(values.GetString(1));
    lines.Free;
    values.Free;
  // Example
  size := GetFolderSize('C:\Movies\');
  ShowMessage(FloatToStr(size) + ' bytes');
