[New] Dark theme
J
[New] Dark theme
Post by J »
I like to share my new HTML-template called "dark theme" with you, which is quite similar to my former "blue theme" and includes the actors part from the Rainbow Seagull theme.
There a two versions, one with actor images, one without.
It contains the font "Syncopate" which can also be dl from Google fonts.
You can use my script "IMDB (actors images)" to automaticly fill your extra pics. As usual, extract to your template dir.
A little more finishing will come with future versions. You need to use AMC v4.2
cheers
J.
Image Image
Dark.zip
UPDATE v4.2.0.1 (Dark.zip)
- IMDB logo included
- better actor handling
- reduced line height
