Exporting error: no argument for format '%s'
daws0n
Post by daws0n »
This error is a recent occurrence since upgrading to the latest version. It happens no matter what file format I attempt to export to or which title I choose to export.
It is a known error?
There might by an error in the translation file you are using.
Which language do you use for the program?
daws0n
Post by daws0n »
Good point! I am using a custom language file I created a long time ago - I will switch back to the stock version and will see if I can replicate the issue.
One of the messages in the [ExportWin] section probably changed. You could try to check which one, but you'll probably get errors in other Windows/messages anyway.
Using a translation file from an old version is not a very good idea, as you can encounter such errors when parameters in messages change ;)
If you make a custom file just for changing some field names for examples, you should either keep only your modified fields in the file, or (if you want another base language than English) copy your modified fields back to the base English file at each new version.
