The Movies DB - Fanart import script
boyerf
Post by boyerf »
Hello,
I try to program a script to import fanart from http://www.themoviedb.org/.
Here, you can find an alpha version. To test it you need to register on the TMDB website and request an API key. You need to provide this API Key in the script.
This script needs the last version of Ant Movie Catalog 4.2.0 Beta.
I need your help to improve it, because I'm not a good programmer...
Best regard,
François
Authors=Boyerf
Title=TMDB_FanArt
Description=Importation de FanArt en provenance de TMDB
Site=http://www.themoviedb.org/
Language=FR
Version=1.0.0 (alpha)
Requires=4.2.0
Comments=Script en construction...
License=
RequiresMovies=1
Debug=0|0|0=Non|1=Mode Debug
[Parameters]
program XBMCFanart;
  StringUtils1;
  URL, GuestID, Img_Value, Img_Width, NewURL, Line, ConfigPath: string;
  Debug, StartPos, BeginPos, EndPos, LineNr: Integer;
  ReturnExtra, NumExtra : Integer;
  RechResult, xFilmID, xTitreFilm, xDateFilm, nbFilmTrouve: string;
  Nbr_ligne_page : integer;
Const
  BASE_URL = 'http://api.themoviedb.org/3/';
(* Enter here the api key !!!! *)
//  Example APIKEY = '?api_key=546545658564645646545465';
  APIKEY = '?api_key=';
function RecupImage(FilmID: string): Integer;
// Récupération de la 1ere image - Nom du fichier et résolution
URL := BASE_URL + 'movie/' + FilmID + '/images' + APIKEY;
Page.Text := GetPage(URL);
LineNr := FindLine('file_path', Page, 0);
if LineNr > -1 then
  BeginPos := pos('file_path', Line) + 12;
  Img_Value := TextBetween(Line, 'file_path":"', '"');
  if debug = 1 then ShowMessage('Nom_image-->'+Img_Value+'<--');
  BeginPos := pos('width', Line) + 7;
  Img_Width := TextBetween(Line, 'width":', ',');
  if debug = 1 then ShowMessage('Taille_image-->'+Img_Width+'<--');
  if debug = 1 then ShowMessage('Chemin complet : '+ConfigPath+'w'+Img_Width+Img_Value);
  // Creation d'un extrafield et sauvegarde de l'image
  NumExtra := GetExtraCount;
  if debug = 1 then ShowMessage('Nbr Extra-->'+FloattoStr(NumExtra)+'<--');
  ReturnExtra := AddExtra;
  if debug = 1 then ShowMessage('No Extra-->'+FloattoStr(ReturnExtra)+'<--');
  SetExtraField(ReturnExtra, extraFieldCategory, 'FanArt');
  GetExtraPicture(ReturnExtra, ConfigPath+'w'+Img_Width+Img_Value);
function RechercheFilm(TitreFilm, DateFilm: string): string;
if DateFilm = '' then URL := BASE_URL + 'search/movie' + APIKEY + '&query=' + TitreFilm
  Else URL := BASE_URL + 'search/movie' + APIKEY + '&query=' + TitreFilm +'&primary_release_year=' + DateFilm;
Nbr_ligne_page := Page.Count;
if debug = 1 then ShowMessage('NB de lignes-->'+floattostr(Nbr_ligne_page));
LineNr := FindLine('total_results', Page, 0);
StartPos := pos('total_results', Line);
RechResult := copy(Line, Startpos+15, 2);
RechResult := StringReplace(RechResult,'}','');
if debug = 1 then ShowMessage('NB de resultats-->'+RechResult);
Result := RechResult;
debug :=0;
If (GetOption('debug') = 1) then debug :=1;
// Configuration de la connection à l'API
URL := BASE_URL + 'configuration' + APIKEY;
LineNr := FindLine('base_url', Page, 0);
ConfigPath := TextBetween(Line, 'base_url":"', '"');
if debug = 1 then showMessage('ConfigPath-->'+ConfigPath);
// Ouverture d'une session Invité
URL := BASE_URL + 'authentication/guest_session/new' + APIKEY;
LineNr := FindLine('guest_session_id', Page, 0);
GuestID := TextBetween(Line, 'guest_session_id":"', '"');
if debug = 1 then ShowMessage('GuestID-->'+GuestID);
// Recherche de film
xTitreFilm := UrlEncode(getfield(fieldTranslatedTitle));
xDateFilm := UrlEncode(getfield(fieldYear));
nbFilmTrouve := RechercheFilm(xTitreFilm, xDateFilm);
if strtofloat(nbFilmTrouve) = 0 then exit;
if strtofloat(nbFilmTrouve) = 1 then
  // recup info film
  xFilmID := TextBetween(Line, 'id":', ',');
  if debug = 1 then ShowMessage('FilmID-->'+xFilmID);
  // recuperation image
  RecupImage(xFilmID);
  exit
  // recup info chaque film
  // affichage liste
boyerf
Post by boyerf »
The difficulty is to code/decode the JSON format (http://docs.themoviedb.apiary.io/). I didn't find a way do to it properly with the script language of AMC. If you have any idea... let me know.! ;)
boyerf
Post by boyerf »
For exemple, how to decode this page properly in a TString List ?
There is Backdrop and Poster. It's important to keep the name of the image, the width and the type (backdrop or poster).
{"id":23051,"backdrops":[{"file_path":"/mR6WnXFvwStdUCSStSFsDKOUECs.jpg","width":1920,"height":1080,"iso_639_1":null,"aspect_ratio":1.78,"vote_average":5.3125,"vote_count":1},{"file_path":"/guEfavznWgbPADTj1hJaQKynRqV.jpg","width":1280,"height":720,"iso_639_1":null,"aspect_ratio":1.78,"vote_average":0.0,"vote_count":0}],"posters":[{"file_path":"/oFQxR31sRVZ5JtNZopkFb8A9rbX.jpg","width":1100,"height":1665,"iso_639_1":null,"aspect_ratio":0.66,"vote_average":5.28273809523809,"vote_count":1},{"file_path":"/jwtiSDSxsS763epDciTs517wELg.jpg","width":1000,"height":1500,"iso_639_1":null,"aspect_ratio":0.67,"vote_average":0.0,"vote_count":0}]}
J
Post by J »
Hello boyerf,
I´m not sure to fully understand the problem, but to get the backdrops from the moviepage why don´t you just use the given links?
for example:
http://www.themoviedb.org/movie/109439- ... r-part-iii
in the HTML you´ll easily find the part
<div id="images">
      <img class="lightbox" id="517aed16760ee31cd81c0ad2" src="http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w300/xIrtFqXc62VGcWKHOsQfCq4j3x0.jpg" width="300" height="169" />
      <img class="lightbox" id="516d49b419c295628314e7a3" src="http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w300/rEXYi7F1Cm4aoYEc9OKrF29gOu4.jpg" width="300" height="169" />
      <img class="lightbox" id="513a4769760ee32030061a82" src="http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w300/zMR2TQ6kH0taKaE4hK82OxBROml.jpg" width="300" height="169" />
      <img class="lightbox" id="51a714d7760ee367f91d522a" src="http://d3gtl9l2a4fn1j.cloudfront.net/t/p/w300/ddqGKr0uDf5Sz4Y9SGI60sL1Uyg.jpg" width="300" height="169" />
    </div>
so you just have to cut the picture links and change "w300" to "original" like
http://d3gtl9l2a4fn1j.cloudfront.net/t/ ... q4j3x0.jpg
No need to use an API-key or JSON.
boyerf
Post by boyerf »
Hello J,
Thank for your help ! You're right, maybe it would be more simple to do my script request with html, but I'm the way with API and I found some solutions.
Now, the script is functionnal. He researches a Movie with the Title and the product date. If there is no result, he researches without the date. If there is a lot of response, he opens a PickList with the list of Movies.
The script catch all the Fanart with a resolution >= 1280.
If somebody want to test it, improve it, let's go.
Best regards,
François
The new version :
Authors=Boyerf
Title=TMDB_FanArt
Language=FR
Version=1.0.5 (alpha)
Requires=4.2.0
License=
RequiresMovies=1
Debug=1|0|0=Non|1=Mode Debug
[Parameters]
program XBMCFanart;
  StringUtils1;
  Debug, StartPos, BeginPos, EndPos, LineNr : Integer;
  RechResult, xFilmID, xTitreFilm, xDateFilm, nbFilmTrouve, idFilmTrouve: string;
Const
	CRLF = #13#10;                        // carriage return/line feed
i : integer;
out : Boolean;
WidthFlag : string;
ImageFlag : string;
// Récupération des image - Nom du fichier et résolution
// Découpage de la page à la hache...
Page.Text := StringReplace(Page.Text, '{', CRLF);
for i:=0 to Page.Count-1 do
  Line := Page.GetString(i);
  if debug = 1 then ShowMessage('Ligne_split-->'+Line+'<--');
  if pos('backdrop', Line) <> 0 then ImageFlag := 'FanArt';
  if pos('"/', Line)  <> 0 then
    WidthFlag := 'w'+Img_Width;
    if debug = 1 then ShowMessage('Width-->'+WidthFlag+'<--');
    if (Img_Width <> '1280') and (strtofloat(Img_Width) > 1280) then WidthFlag := 'original';
    if debug = 1 then ShowMessage('Appel_Image-->'+ConfigPath+WidthFlag+Img_Value+'<--');
    if (strtofloat(Img_Width) >= 1280) then
      SetExtraField(ReturnExtra, extraFieldCategory, ImageFlag);
      GetExtraPicture(ReturnExtra, ConfigPath+WidthFlag+Img_Value);
//  if pos('posters', Line)  <> 0 then ImageFlag := 'Poster';
  if pos('posters', Line)  <> 0 then exit;
i : integer;
//if debug = 1 then ShowMessage('NB de lignes-->'+floattostr(Nbr_ligne_page));
function SelectMultiFilm(TitreFilm, DateFilm: string): string;
i : integer;
Rech_Title, Rech_OTitle, Rech_Date, Rech_ID, Pick_Line, Pick_Return : string;
  for i:=2 to Page.Count-1 do
    if pos('title', Line) <> 0 then
      Rech_Title := TextBetween(Line, 'title":"', '"');
      Rech_OTitle := TextBetween(Line, 'original_title":"', '"');
      Rech_Date := TextBetween(Line, 'release_date":"', '"');
      Rech_ID := TextBetween(Line, 'id":', ',');
      Pick_Line := '"'+Rech_Title+'" --- "'+Rech_OTitle+'" --- '+Rech_Date+' --- '+Rech_ID;
      if debug = 1 then ShowMessage('Pick_Line-->'+Pick_Line+'<--');
      PickTreeAdd(Pick_Line,Rech_ID);
  if PickTreeExec(Pick_Return) then RechResult:=Pick_Return;
  if debug = 1 then ShowMessage('Pick_Return-->'+Pick_Return+'<--');
Result := Pick_Return;
debug :=0;
  xDateFilm := '';
if strtofloat(nbFilmTrouve) > 1 then idFilmTrouve := SelectMultiFilm(xTitreFilm, xDateFilm);
if strtofloat(nbFilmTrouve) = 1 then idFilmTrouve := TextBetween(Line, 'id":', ',');
RecupImage(idFilmTrouve);
Teebee
Post by Teebee »
I get a 'HTTP /1.1 404 Not Found' eery movie i try to check.
Have latest version of antp and script
boyerf
Post by boyerf »
Teebee wrote:I get a 'HTTP /1.1 404 Not Found' eery movie i try to check.
Hello,
Do you have an APIKEY ? (http://www.themoviedb.org/documentation/api).
After requested a KEY on the TMDB webside, you need to put the KEY in the script.
Teebee
Post by Teebee »
Yes, have an APIKEY, and put it at the right spot.
[/img]
boyerf
Post by boyerf »
It's strange... I test my script with 800 différent movies...
For your movies, do you have something in the "Translated Title" field ? This is the field used by the script. And do you try to activate the debug mode in options ?
Teebee
Post by Teebee »
oh, that was the issue.
Almost none of my movies have Translated titles :grinking:
When i added one it found the movie immediately!
boyerf
Post by boyerf »
Hello Teebee !
You can modify the script for your configuration.
just change the line :
by
xTitreFilm := UrlEncode(getfield(fieldOriginalTitle));
I must improve the script and add some options and verification....
Tell me if you find it usefull !
Enjoy !
fagnerpc
Post by fagnerpc »
Thx for the amazing code, boyerf :grinking:
I've made some simple modifications and the code is fully functional with 4.2 and the newest beta release.
Tested on +100 different movies with success (the script is incredibly fast)
Authors=Boyerf
Title=TMDB FanArt
Language=FR
Requires=4.2.0
License=
RequiresMovies=1
[Parameters]
program XBMCFanart;
  StringUtils1;
Const
i : integer;
out : Boolean;
WidthFlag : string;
ImageFlag : string;
  if pos('backdrop', Line) <> 0 then ImageFlag := 'Backgrounds';
    if (Img_Width <> '1920') and (strtofloat(Img_Width) > 1920) then WidthFlag := 'original';
    if debug = 0 then
      GetExtraPicture(ReturnExtra, ConfigPath+'original'+Img_Value);
i : integer;
i : integer;
debug :=0;
  xDateFilm := '';
Should it replace the current TMDB script? Or (I suppose) it is rather just an additional script, to put as extra beside the one already included?
fagnerpc
Post by fagnerpc »
antp wrote:Should it replace the current TMDB script? Or (I suppose) it is rather just an additional script, to put as extra beside the one already included?
Yep, kind of a additional script.
This script only imports backdrops (backgrounds), posters and fanarts in general to extra fields. Probably, it's the only (functional) script that import fanart from TMDb right now.
Could import others fields in a further improvement, but I think it's kind of pointless, since the very TMDb exchange information with IMDb.
An combo IMDb + TMDb Fanart is more appropriate...
KRiSZK0
Post by KRiSZK0 »
Great script, working fast :grinking:
Will you guys add posters to the script? Now it only download backgrouds.
pacomania2005
Post by pacomania2005 »
Hello boyerf,
I'm using Your script for TMDBFARNAT, when I'm searching the title (in english or italian) I can't download any image.
I tried to modified the script, in original language or translated but I don't have any result.
How can I do?
Giulio
boyerf
Post by boyerf »
pacomania2005 wrote:Hello boyerf,
How can I do?
Giulio
Hi, new version with some corrects.
Authors=Boyerf
Title=TMDB_FanArt
Language=FR
Version=1.1
Requires=4.2.0
Comments=Beware, this script use fieldOriginalTitle for research !||And in the script, you need to modify the API Key !||To obtain an APIKey, visit the TMDB site and create an account :|https://www.themoviedb.org/documentation/api
License=
RequiresMovies=1
[Parameters]
program XBMCFanart;
  StringUtils1;
Const
  APIKEY = '?api_key=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx';
i : integer;
out : Boolean;
WidthFlag : string;
ImageFlag : string;
    Img_Width := StringReplace(Img_Width, '}', '');
i : integer;
if debug = 1 then ShowMessage('RechercheFilm - URL-->'+URL);
RechResult := StringReplace(RechResult,',','');
if debug = 1 then ShowMessage('RechercheFilm - NB de Films trouvés-->'+RechResult);
i : integer;
  PickTreeAdd('Film --> ' + UrlDecode(TitreFilm) + '[' + DateFilm + ']','');
debug :=0;
if getfield(fieldOriginalTitle)<>'' then xTitreFilm := UrlEncode(Cp1252ToASCII(getfield(fieldOriginalTitle)))
  else xTitreFilm := UrlEncode(Cp1252ToASCII(getfield(fieldTranslatedTitle)));
  xDateFilm := '';
pacomania2005
Hello boyerf,
thanks so much
Giulio
