Bug with Media Files Import
elman
Post by elman »
Hi, I'm trying new 4.2.0.1 and I'm having problems importing media file. When I drag and drop any mkv or xvid file, nothing happens. Could you please check it out? Thanks
Post by soulsnake »
Hi elman,
Drag & drop files on movie list (on left) and it should work.
I will fix this for the next update to have the same behaviour than before.
Actually I do that inially because now you can also drag & drop files on extras list to import extras.
elman
Post by elman »
soulsnake wrote:Hi elman,
Ah, thanks for the info. Will try that.
