Release: CD-Case templates
jesped
Post by jesped »
Just some CD-case templates I made for my Wortex CD case bags (I think it's standard size).
http://www.geocities.com/SoHo/Gallery/1 ... plates.zip
Thanks, it looks good, I'll include it. (I modified it so it can be used to print more than one movie at a time)
jesped
Post by jesped »
Thanks.
It will be great to print more than 1 cover at a time, it's kinda tedious to go one at a time ;)
Anyway, the worst lack for me at this time is the need of more scripts for spanish and adult sites, and the posibility to mix fields from different sites at the same time.
I looked at some of the scripts trying to do it myself, but I found them too complicated for me :ha:
are you working on more scripts in that way?
and when the new version will be available?
Many thanks, you're doing a great jobe there pal.
I'll try to make something more easy in the future for the scripts, to allow to combine them easily without needing of rewrite/modify the scripts for each combinaison.
If you want to be informed when the program is updated or when a new version is released, you can subscribe to the newsletter at www.ant.be.tf/moviecatalog
jesped
Post by jesped »
I already suscribed. Many thanks ;)
@pitbull
Post by @pitbull »
the url don't work :(
You have to copy/paste it to a new window ;)
Geocities does not allow to link file from other servers
@pitbull
Post by @pitbull »
Can you explain me how to use this script?
it is not a script, only a template for printing
so expand the .zip file to the Templates folder, then go to File -> Print and select it in the list ;)
